install of ...MSD Atomic EFI...pn# 2910
Discussion in 'Maverick/Comet Projects' started by 71gold, Aug 9, 2014.
  1. 71gold
    the wiring was a lot simpler than I thought it would be.
    1-blk.
    2-red
    1-yellow
    everything else just plugs in...:drive:
    ...EFI for dummies...
  2. 71gold
    it has the option of a hookup for A/C fast idle.
    option for running 2 fans.
    and timing control for you guys and gals running a dist.
  3. 71gold
    here is the next step...one more to go.
  4. 71gold
    done...now to get it out and see if it will...:drive:...:chirp:
    Mavman72 likes this.
  5. bmcdaniel
    bmcdaniel Senile Member
    Frank, does that red module thingy have to hang off the side like that?
  6. Pony Express
    Pony Express Haul'in @**
    DelMarVa
    1976 Maverick
    I have also read an excellent review on this system, but it was on an turbo'd LS3.
  7. 71gold
    no...see pic. in post #19. this is just how I chose to mount it.
    it can be mounted inside the car if you like.
  8. 71gold
    ran it for about 200 miles on interstate...ran great. do notice more pull and no lag in throttle response.
  9. rthomas771
    Notice if gas mileage improved with the technology?
  10. Dave B
    Too bad it's not on a Ford engine, then it might apply to more people around here.
  11. 71gold
    the subject of the thread is...MSD Atomic EFI...should apply to Ford engines also.
    one MPG better...(y)
  12. Wilbur Green
    Wilbur Green Member
    Plymouth, Ohio
    76Stallion, 762dr.
    Good job Frank, sounds like a great set up.
  13. 71gold
    thanks Wilbur...:Handshake:
  14. 71gold
    now that this is up and running...back to the exhaust manifold project....:outtahere:
    M.A.V. likes this.
  15. 71gold
    got a chance to check the...cold start on the Atomic EFI...yesterday.
    40 degrees...hit the key, it fired right up.
    went to 1200 RPMs for 2 secs. and dropped down to 650 RPM and set there and ran. I hopped in and took off. there was no cold start bog or anything...:thumbs2:
