Installing 427 Windsor in 71 Comet
Discussion in 'Drag Racing' started by rodthedeerguy, Jul 1, 2012.
  1. cometgtngrabber
    cometgtngrabber New Member
    spa tn
    72 grabber 73 comet gt 65 mustang 49 ford club coupe 90 ssp mustang
    i've seen it done in a 65 mustang it went 6.7 in the 1/8 not sure wat was done to the motor but he said it just had block headers
  2. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Best 1/8th ET so far with the 3.00 and 274 RWHP was 8.2XX at 85.XXX MPH. I guess with 3.55 my cruise RPM would be around 3500-3800. I'd like 3.55s with OD.(y) It all depends on how tall the tires are, what RPM your engine likes, and how much Interstate driving you do.
  3. CometGT1974
    CometGT1974 Gearhead
    Western NC
    74 Comet GT
    This thread needs some pics!! :D Here's how I notched mine (w/ a strut conversion) I also built custom headers that were 2"-2 1/8" stepped. Car went 5.50 w/ that setup. I sold the headers and am now building a set of .035 wall 321 SS, fenderwell exit headers.
  4. CometGT1974
    Western NC
    74 Comet GT
  5. groberts101
    groberts101 Member
    Minneapolis, MN
    very nice work.. and I dig the design!
    Thick flanges that give lattitude for better matching and even transitioning out of the heads ports where needed.. and it's damned close to equal length with a 3.5 inch(or maybe 4 inch?) collector to fatten up the midrange and top end. That's a big motor.. and that header fits it nicely if you have the big lift and duration cam to match up with their tune.
    did you use pipe max or any other tuning software to develop it.. or just running off experience and other known good recipes while maximizing it for chassis clearance and exit strategy?
  6. groberts101
    groberts101 Member
    Minneapolis, MN
    IMHO, that's a pretty wide variation in potential config's there based on displacement and head choice. Imagine all the parts/tuning changes between a 408 with 225 heads.. and a 427 with 205's. First one rev's higher with a softer bottom end and needs more gear to even keep up with the torquer 427. That is if you can get enough traction to allow the 427 to hook off the line. lol
    Based on those examples I would guess that a litghter car with adequate tire and traction aids would be "more streetable" with 3.30-3.50 final drive(after tire size is considered). 427 get's the 3.30.. 408 gets the 3.50.
    Also IMHO, 3.00 and taller gears are for cruising and light hearted playtime. Not for smallblocks that like to rev.. no matter how much torque you think you have down low with a bigger cam. Really just depends on how hard you want to focus on the traction department.. how rowdy you are on the streets.. and if you like being on the cam more often then not.. without having to work the shifter and go pedal to put it there. Most of the guys running those taller gears effectively are the big-block strokers or superchargers. I can say from experience that they do make great gears for burnouts with 3 speeds though! lol
    PS. also consider that if you do ever want to race it down the strip.. 300 gears with a revvy motor/cam will barely even allow you to make 3rd gear by time you reach the line. So, much of the time.. you're effectively driving a powerglide with an overdrive. :D
  7. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    351 into a Comet
    Hello again Rod:
    I removed the shock towers and after the engine was installed , changing the plugs was a breeze. All kinds of room. I did have to "relieve" a couple of spots on the INSIDE of my Trick Flow Valve Covers so it would clear the roller rockers and
    just one small spot on the OUTSIDE to not rub against the master cylinder edge. They sell covers that fit nicely after the towers are removed and they can be welded in afterwards and painted . ROD & CUSTOM sell these along with their front end setups. Keep on charging man .. its worth the effort.
    Cometized
  8. olerodder
    olerodder Member
    NorCal
    Very, Very nicely done.
    Would love to see some pictures of the fender well headers.
  9. ScottStaypuff
    ScottStaypuff Member
    Ohio
    1971 Maverick Grabber
    I like the idea of shorter slicks at the track if needed.
    I had short slicks on my other car and went from a 3.55 to a 3.94 final drive and it was a mistake, just didn't have the revs to pull it off and it didn't go any faster. Highway driving just got worse. lol
  10. CometGT1974
    Western NC
    74 Comet GT
    I spoke w/ the guys at burns stainless and stahl headers and also drew on a few books and just overall experience. Basically, in a door car w/ such limited space you just do the best you can with the space available. Mavericks are so limited on space, it's hard to get real crazy w/ header design. Also, mine is an all out nitrous car so header design is not quite as crucial as an all out N/A design.
  11. groberts101
    groberts101 Member
    Minneapolis, MN
    yep.. pays to hang on the coattails of the big dogs when trying to accellerate the learning curve.. that's for sure.
    Nice setup.. and you surely maximized what you had to work with there from an architecture standpoint.
    Now just set them up so I can run a sidepipe from the collector and let me know how much they'll cost me. :D
  12. CometGT1974
    Western NC
    74 Comet GT
    I sold those headers to a guy that said if they wouldn't work on his car he would just hang them up as art in his garage. Wait until you see the fenderwell exit headers, they will be impressive!
  13. rodthedeerguy
    rodthedeerguy Member
    Jacksboro, TX
    2012 Super Cobra Jet #037
    Shock towers
    WoW! I love what you did here. Makes a lot of sense. Thanks for the idea and info.
  14. rodthedeerguy
    Jacksboro, TX
    Awesome
    Those are awesome. I want a set!!!
  15. CometGT1974
    Western NC
    74 Comet GT
    You're a good drive away but if you can get your car here, you can have a set!! (y)
