INSTALLING 58 FORD 9 INCH
Discussion in 'Technical' started by maverick7072, Oct 11, 2016.
  1. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    hope u r right quick shift ,maybe it will work without cutting the shaft!
  2. Krazy Comet
    Dismal Swamp
    Without driveshaft locked most will turn axles same direction even though they are single traction...
    AFAIK posi wasn't available that far back...
    A 3.10 gerar would have likely came behind a 292 & automatic, at least that was usual ratio for '57... Wagons with same engine & trans got 3.56...
  3. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    not sur ehwat engine it had but it was a automatic car! krazy comet when i hold one axle and try to turn th eyoke it wont turn,now yrs ago my cousin had a 58 pickup that came with 3.70 gears and posi unit or at least when he put a 390 bigblock in it and did burn outs it would leave to marks,now after a few hard launches and brn outs it stopped leaving 2 black marks it was the orginal war case
  4. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    my 8 inch in the maverick has 2.79 gears does anyone think i will notice a little btter acceleration with the 3.10 vs the 2.79
  5. Krazy Comet
    Dismal Swamp
    Probably not, just using taller/shorter tires can change the actual final ratio as much if not more... With 255 on back of mine I had to switch speedo gear from orig 3.00 to a 2.79 gear to get a correct reading...
  6. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    i have found a center section out of a truck with 3.50 gears ,the truck section is from a 73 f-100.i have 28 inch rear tires and a 2500 stall so i think the 3.50 gears would be better suited for my driving in town mostly
  7. Krazy Comet
    Dismal Swamp
    Need to be sure that pumpkin has 28 spline axles...
  8. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    actually when i went to pick the centersection up it wound up being a 2.75 gear but luckily Carl had another 9 inch sitting around that actuallly did have the 3.50 gear,he had a 3.70 chunk i almost went with but decided the 3.50 would be the best comprimise, cant wait to install the 9 inch with the 3.50 gears gotta be more fun than the 2.79 gears
    Krazy Comet likes this.
