installing power windows...
Discussion in 'Technical' started by 71gold, Sep 30, 2020.
  1. 71gold
    took the first step to installing the power windows...
    opened the pass. side door and looked at the door panel.
    step two tomorrow...get tools to remove window crank handle (screwdriver) and armrest (deep well socket).
    step three...
    removed window crank and inside door handle.
    Stefan and BBMS18 like this.
  2. 71gold
    drilled the holes for the wires going through the door into the door frame. installed the little boot the wires run through.
    got the pass. window reg. going up/down.
    need to get the glass in and see how it does.
    BBMS18 likes this.
  3. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    More details please.
  4. TeeEl
    TeeEl Senior Member
    Colorado
    What power window kit are you installing?
    I want to put them in another project car of mine (not the Maverick)...
  5. 71gold
    TeeEl likes this.
  6. 71gold
    got the pass side installed and working...:thumbs2: need to get door panel and handles on...(pic later).
    the only mod so far...
    the window would drop about 1/4" to the front side.
    slotted the hole for the equalizer arm about 3/8" down...doing this leveled the glass, now up/down wide open both ways.
    ...:bouncy:...
    BBMS18 likes this.
  7. CA189HJN
    CA189HJN Robert Couse-Baker
    Sacramento, California
    1973 Ford Maverick 4-door 302
    Sweet!!! It looks like a well-engineered kit. As they say, pay up front for quality and only cry once.
    mojo likes this.
  8. 71gold
    I changed the outside door handle today. I ordered a set of them maybe 3 years ago and said if I ever had the door panel off I would replace it...done.
    I have the new inside door handle and window crank I had powdercoated coated black (3 yrs ago) ready to go on tomorrow after I install the door panel...:smash:
    CA189HJN likes this.
  9. 71gold
    pass, door done...:thumbs2:
    handle down...window down.
    handle up...window up.
    has 1/4 " movement.
    scale of 1-10...with any mechanical skills...a solid 3.5.
    Earl Branham and BBMS18 like this.
  10. mojo
    What your saying: difficulty level w/ some mechanical skills on scale of 1-10 is 3.5?
  11. 71gold
    yes,,,:yup:
  12. Earl Branham
    Lugoff, SC
    Well done Frank! I might try that after I get the little bit of body work done.
  13. x72COMETx
    x72COMETx Member
    Vallejo CA
    Can you control the passenger side window from the driver side without leaning over to push the handle?
  14. 71gold
    not with the set of controls I have
    they have several different configurations of switches.
  15. 71gold
    got the driver side pulled down. drilled the hole in the door frame, hope to get the one in the door tomorrow.
    Dr. appointment ate up my day...:bouncy:
