believe it or not some canadians actually use the word eh..... I know I use way to often..... you should hear my newfie friend talk, she never uses the word my, she always uses the word me... like meself instead of myself or I cut me finger
another update tonight, started by 10:00 got the motor pulled by 12:30, forgot to undo the torque converter bolts and poured tranny fluid all over the floor and quickly had to grab a container to catch it all, so I got my power steering fixed, new flexplate in, and new tranny lines and the motor is now back in the car. none of the motor or tranny mount bolts are tight but everything is held in place. got the headers back on, seem to have lost a header bolt somewhere???? anyway calling it quits for the night, finish it off tomorrow. still have to put in the driveshaft and shifter linkage in. also have to put the speedo in and the gears but I wasn't climbing in my car as dirty as I am right now. also have to put in the rad and tranny cooler in again. think thats pretty much it, but I need 2 new spark plugs and forgot to pack up new collecter gaskets when I went to Canadian Tire so once I get the car finished I will update you on anything else I happen to break
Bulb Swap Worked on the car a while today seeing i need to put my new Headlght knob on and so im putting a new radio in it plus I went ahead and did the bulb swap and also painted the blue parts white. Man I cant believe the difference.I CAN SEE, Its a miracle Thanks for all the posts and I would recomend this upgrade to every one. Later Tim
