intake comparison
Discussion in 'Drag Racing' started by Gent, Apr 20, 2008.
  1. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    My cam didn't really make power until very close to 3k...
    So that would explain why I didn't see a change in bottom end.
    My combo must have been just right then.
    Intake on at 3k, cam on at 3k...
    I suppose we need to know about the combo in question and when the cam comes in. If it doesn't start low, why would someone want a lower RPM intake? It seems to me it would waste your cam's potential on the top, and the lower end power promised by the manufacturer would not be realized.
    Is my thinking flawed?
  2. mavman
    mavman Member
    Arkansas
    I certainly don't think so. After all, the whole key is to match your parts.
  3. bossmav
    bossmav Drag racing nut
    Harrisonburg, Va
    74 Grabber now Pearl white
    I agree Mavman, putting a Vic Jr on a 289, 302 is not the right thing to do on a street machine. That's what I was trying to get at.
    Picking a intake to match the rest of your motor is the best way to go.
    A mild to stock bottem end with a mild cam should use a duel plane intake.
    I'm sure I wouldn't use a 850 on it but that's just me.
    Here is a site to some Edelbrock intakes, look at the RPM range and get the one that's fits your needs.
    http://www.performancecenter.com/intake-manifold
    The one major factor to keep in mind here is your heads, your can have the best of everything, but if your heads won't flow, you won't go.
    That's the very sad truth about SBF's the exhuast side almost always needs help.
    Good luck.
    Bossmav
  4. Gent
    Gent Member
    virginia
    72 grabber
    The track was slick, raining off and on, could not hook up will try again next week.
