Intake install
Discussion in 'General Maverick/Comet' started by rag9836, Jul 16, 2016.
  1. rag9836
    rag9836 1972 Comet, 67K
    Riverside, CA
    Comet
    another newby question? Is it nessasary to trim the felpro gasket when installing a new intake manifold?
    Should I put the permatex ultra black around the water ports?
    The gasket instructions call for using tack to hold gasket in place... Is this also nessasary?
    Thanks guys.
  2. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I use Gaskacinch to glue the gasket to the cylinder head and I use blue RTV around the water jackets. I also glue the cork end-seals with 3M weatherstrip adhesive.
  3. rag9836
    Riverside, CA
    Comet
    Do you trim the gasket?
  4. rag9836
    Riverside, CA
    Comet
    Noticed this was sheered off from what looks like the exhaust.
    Ideas on what this is?
    Thanks
  5. Hotrock
    Munroe Falls, Ohio
    The tube pictured uses exhaust heat to warm the thermostat coil. The threaded end should connect to your thermostat cover assuming someone hasn't replaced the heated unit with an electric powered cover and coil.
  6. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Which gasket, and what part of the gasket are you referring to? On stock replacement gaskets, I don't do any trimming. Some of the Felpro performance gaskets are universal for 302 and 351, so some trimming on the water jacket openings is necessary.
  7. 71gold
    choke tube......
  8. rag9836
    Riverside, CA
    Comet
    Thanks guys. I have the Fel-pro 1250 gaskets.
    Ordered some tack and will trim the excess.
    The choke tube sheered off right into exhaust manifold.
    I have some Doug's headers and will try and install them while I have everything off.
    Appreciate all the help guys.
