Integral Brazillian Tach - Concept Drawing
Discussion in 'General Maverick/Comet' started by cactusgrabber, Oct 2, 2011.
  1. Bryant
    pretty cool. that will make a great tech article
  2. maverick75
    That's awesome!
    The first Sunpro tach I got bit the dust after a month, then all they had were the black face ones left. This one has lasted ever since 2007.
    [​IMG][​IMG]
    How do you remove the faces? I'd like to swap mine out to the white one since I have the matching gauges for that. Thanks!
    I always thought these SW looked similar to the factory ones.
  3. cactusgrabber
    cactusgrabber Member
    Tempe, Arizona
    72 Grabber
  4. cactusgrabber
    Tempe, Arizona
    72 Grabber
    On the Sunpro Model I used, I took the tach guts out of the case, then I carefully took the pointer off with a Trim remover tool, that slips under each side of the center of the pointer, then I used a small philips screwdriver, and removed the 2 screws holding the dial face on.
  5. maverick75
    Thank you :Handshake
