Interior how tos
Discussion in 'Technical' started by smegnl, Jan 30, 2023.
  1. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    I looked and looked but didnt see anything. Is there a thread on here about putting the interior back together? Mine was removed many moons ago by the body shop. I got the interior all painted, carpet in, steering wheel fixed, sound mat. So now its time for side panels and kick plates
    So many questions. I was hoping there was a thread on it. Like does the carpet get trimmed around the side panels or do they go over it. Is there more then the 2 screws that are easy to see? What size / thread?
    If there isnt one, guess Ill make one as I go.
    Thanks.
    Russell likes this.
  2. mojo
    IIRC, I installed my carpet under the kick/seat rear panels and metal door strips.
    Russell and 71gold like this.
  3. Krazy Comet
    I don't remember any Ford that carpet doesn't slip under sill plate & behind kick panel.
    Russell likes this.
  4. Russell
    Russell Orejano
    New Mexico, 88022
    Maverick
    Thats ok...I can't remember either...after I got up from the dinner table the third time, I told my wife, "When I get to the refrigerator, yell BUTTER!" p.s. two screws on kick panels, carpet under chrome....
    Shorty and Krazy Comet like this.
  5. rthomas771
    60-65 Falcon had what they call wall-to-wall carpet option back in the day. I used it in my '60
    Ronald Hopkins likes this.
  6. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    OK, so door arm rest. I got a door panel, the plastic arm rest base and and arm rest. How does the base attach? I dont see any screw holes. Do I need those L shaped retainer clips with the bolt hole? What bolts go thru the arm rest and into the base? Thanks. Would be easier if I had been the one who gutted the car, but I am not so I didnt see how it came apart.
  7. CaptainComet
    Regarding kick panels, the screw hole location moved a bit early years versus later. I forget exact details here but they are just sheet metal screws and drilling a new pilot hole is a simple fix.
    Armrest - yes- L shaped clips and a hex head screw. I should have a bag of that hardware here if you need them.
    smegnl likes this.
  8. Ronald Hopkins
    Ronald Hopkins Member
    Morristown Tennessee
    1972 Comet GT
    Also the 64 1/2 Mustangs does not go under the sill plate.
    rthomas771 likes this.
  9. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    It is at an angle, but I guess thats normal.
  10. 71gold
    the 70 sill plate is different from the other years...it's bigger.
  11. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    There is no way that screw is going into that welded bracket on the body. I have other two screws in, but not this one.
  12. 71gold
    are these the original panels for this year car?
  13. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    I have no idea. They were in the car when I got it. The front grill was wrong as well as the hood. So anything is possible.
    Once I put the upper deck in I can put a bolt and spring nut on it and slide it into the metal u grove on the metal side molding.
  14. CaptainComet
    LOVE the sill plates. I think they were 1970 only.
  15. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    When you get the quarter trim installed it will push the back of the sill plate out a bit
