Interior paint
Discussion in 'Cosmetic' started by maverickoutlaw, May 31, 2015.
  1. maverickoutlaw
    maverickoutlaw Member
    St Marks, Fl
    1973 maverick
    What interior paint would i need to use on my car? I used Ace brand satin black but it just doesn't look right.
    It seems to be too flat. I would rather use a spray can if i can find the right shade.
    thanx ray
  2. 73curtis
    73curtis Member
    ohio
    spray max satin black in a spray can looks really good, has a good spray pattern.
  3. rthomas771
  4. jasonwthompson
    jasonwthompson Member
    Carrollton TX
  5. 73curtis
    73curtis Member
    ohio
  6. Craig Selvey
    Your dash should have a "hint" of metallic.
  7. maverickoutlaw
    St Marks, Fl
    1973 maverick
    Just the dash?
  8. Craig Selvey
    The heater control bezel and the instrument cluster bezel have a hint of metallic as well.
  9. jasonwthompson
    Carrollton TX
    I don't know if it was factory, but it looks pretty close. It is not a heavy metallic, if it is not in direct sunlight you would probably not be able to tell there is any metallic to it.
  10. LukeDuke
    LukeDuke Member
    Oklahoma City
    1976 Comet
    I used fabric and vinyl paint from OREILLY 6 years ago and it still looks perfect I used it on the metal dash and the door panels and the back seat. The only thing I did to prep was clean everything with orange soap to remove any grease.
  11. 6inarow
    6inarow Member
    71 maverick
    I've also had good results from rustoleum satin black. Looks factory with a tiny shine. I used that paint on interior stuff, outside trim. Haven't used many produstc on my Mav, so all me experiences with paint and whatnot is on German steel.
  12. mav1970
    Your dash is made of steel - you must be referring to the dash pad on top which is not :yup:
