Intermittent starting issue
Discussion in 'Technical' started by joerockne, Aug 23, 2021.
  1. joerockne
    joerockne Member
    Norman, OK
    1972 Grabber Maverick
    I am trying to get my Maverick running. I did get the 302 started and it sounds fine ! I replaced the starter, the solenoid, battery cables etc. But I am having an issue. Turning the key and nothing now. I have to try and trace whats going on. I am not real familar with Fords and their problems. I was thinking maybe ignition switch or connections there? Anything else common I should check?
  2. 71gold
    try adjusting the ignition switch at the base of the steering column.
  3. joerockne
    joerockne Member
    Norman, OK
    OK I will try that first. Maybe the rod is not actuating it. Its so freakin' hot right now I am not making much progress.
  4. 71Mavrk
    71Mavrk Member
    Nevada
    I had a neutral safety switch that would make intermittent contact. Drove me nuts until I figured it out and just jumped the connection.
    Micah
  5. joerockne
    joerockne Member
    Norman, OK
    IS that switch in the shifter or under the dash? I have a floor shifted car.
  6. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    It’s on the transmission at the shifter arm.
  7. joerockne
    joerockne Member
    Norman, OK
    Thanks . I may jack it up and take a look.
  8. joerockne
    joerockne Member
    Norman, OK
    I had some time and jacked the 72 up. I did not see any switch on the tranny. It was a factory column shifted model converted to floor shift I think. I did see that switch at the base of the column. Somebody cut the green wire , extended those wires and had connectors on them. My feeling is maybe they went to a hidden "kill" switch? If that green wire has a break in it, does that prevent starting the car ? I have to test tomorrow, but my guess is it does.
  9. 71gold
    did you try moving the shift leaver while you hold the key in the start position? or even put it in neutral and see what you get.
  10. joerockne
    joerockne Member
    Norman, OK
    I think I tried that a few months ago. But I will again tomorrow. It is a floor shifted automatic. The column I put in it was column shift auto, minus the lever. I am 99.9% sure I already moved it around. I just found the break in the green wire so I suspect somebody put it in there for a reason.
  11. Krazy Comet
    Dismal Swamp
    Wire from ign switch to neutral safety & on to "S" terminal of solenoid should be a red wire with blue stripe. First check at S terminal, then on said R/B wire at ign switch plug. From that point work toward neutral safety from switch. A test light will reveal when wire has power.
  12. joerockne
    joerockne Member
    Norman, OK
    I tested it with the light at "s" with the key in the on position. It did not have power. I pulled the plug apart with the red and blue striped wire apart. There was no power there either.
  13. Krazy Comet
    Dismal Swamp
    There is only power at the red/blue when it's connected to switch, and in start position.
    Main feed to switch is a slightly larger yellow wire. In start, switch routes power from yellow to the Red/Blue.
  14. 71gold
    sounds like you are on the right track...:yup:
  15. joerockne
    joerockne Member
    Norman, OK
    Just to be sure, that wiring to the distributor does not play any part in the turning over of the starter does it? I unhooked the old distributor wiring and put an HEI in . I ran a direct wire from the battery to the HEI and jumped the solenoid on my test fire ! It ran and I think its ok.
