Is it a 7.5 or 8.8 ???
Discussion in 'Technical' started by elliot, Sep 4, 2005.
  1. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Yeah, I remember that guy. I never ever knew they had 8.8 for those cars. Learn sumthin new today.
  2. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    I looked at a Maverick here in NC that has a rear like that.
    It is a 5 lug with the rear bolted on cover.
    The axles have the holes counter sunk in the head-at the
    hub-kind of like 31 spline axles.
    Seth
  3. MapleMav
    MapleMav Member
    Moose Jaw, SK Canada
    '72 Sprint
    If it's an early Granada, and the rear's never been swapped out of it, I'd say it's most likely an 8.7, which apparently was a fairly weak unit. According to what I've read, Ford didn't introduce the 8.8 until 1986.
  4. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    That sounds about right...
  5. Charlie
    Charlie maverick.to/grabber
    Indianapolis, IN
    1970 Ford Maverick Grabber (Modified)
    I've never heard of the 8.7, but yea, I thought the 8.8 didn't come out until at least 1979. Which is after the leaf spring Granada era.
  6. Bluegrass
    Bluegrass Jr. mbr. not really,
    Easton, Pa
    73 Comet GT, EFI, C4, Posi
    If anyone would seriously like to use an 8.8 in a Mav for the ease of gear selection and traction lock, take a look at the later Explorers with leaf springs.
    The spring pads may need to be relocated and some other minor mods as well as using the correct wheel offset.
    Don't worry about the 8.8 strength, there larger and take a beating in late Mustangs.
    I have the same rear (8.8) in a 3900 lb Lincoln with a Kenne Bell blower up front.
  7. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
    The granada is a '77 , it had a 250/C5 . I pulled the rear end and I will get a better picture of it tomorrow.
  8. elliot
    elliot Member
    Boubon MO
    Well it took me long enough but here is a picture of it out of the car . Every one think its an 8.8 still ?
  9. Charlie
    Indianapolis, IN
    Looks similar at least. The tags on it, why dont cha take it off and post what it says (or take a photo? :)
  10. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I don't remember what the inch size is, but I read on a Stang site this rear is a transitional design that evenutally became the 8.8, but wasn't quite there yet.
  11. mavman
    mavman Member
    Arkansas
    whoa, wait. Wasnt there a 6 3/4 rear made?
    I believe I've seen something like that in a Maverick before....in a boneyard.
  12. MapleMav
    MapleMav Member
    '72 Sprint
  13. elliot
    elliot Member
    Boubon MO
    The tag says WER-AC 7DE
    2 47 8 7 57 6A
    If its an 8.7 is it worth anything but scrap metal ?
  14. ratio411
    ratio411 Member
    Pensacola
    2.47 peg leg!
    Wow, talk about an economy gear set!
  15. elliot
    elliot Member
    Boubon MO
    Salt flats here I come !!! :D
