Is my oil pressure too high?
Discussion in 'General Maverick/Comet' started by vvr210, Oct 23, 2012.
  1. vvr210
    vvr210 Member
    Vista,CA
    This morning I drove the car to school..Initially the pressure was around 62.On the way back after school after the engine warmed up the pressure dropped to 55 and it would go up to 60 when I was doing 65MPH
    I went out earlier to check the oil level and it was at the "N" of Warranty
  2. simple man
    simple man Member
    Bunnell,Florida
    My 74 Maverick 250 holds 4½ quarts of oil. It always has and that's what the book says too. :)
  3. vvr210
    vvr210 Member
    Vista,CA
    According to my Chiltons manual a 250 uses 4.5 with filter 3.5 without filter.A 302 holds 5.0 with filter and 4.0 quarts without.So I guess I couldn't of overfilled it.
  4. simple man
    simple man Member
    Bunnell,Florida
    Yeah, just drain a pint out and your dipstick reading should be right on! :)
  5. simple man
    simple man Member
    Bunnell,Florida
    Thought I'd make a new post so this will show up for you. One thing to check for a running oil leak is the oil pressure switch. This is screwed in on the left side of the engine about 4" forward from the crankcase/transmission joint. It sets all by itself with one wire plugged into it. These can leak bunches of oil at road speed! It will run down the side of the block and drip from the back of the oil pan. You'll see if it's leaking as there will be a nice fresh oil slick from it! You can get this at Napa too! :)
  6. jayss10
    jayss10 This is Minerva
    INDIANA
    1971 MAVERICK,73 GRABER CLONE
    mine runs 70 to 85psl all the time it doesnt use any oil
  7. vvr210
    vvr210 Member
    Vista,CA
    Would this be the switch?
  8. Krazy Comet
    That's the correct spot but that's the fittings & line installed to the oil pressure gauge, the sender(switch) has been removed... With no dirt on the side to the front, likely it is your leak(oil has washed away the dirt build up)...
  9. vvr210
    vvr210 Member
    Vista,CA
    Is this probably the reason why my Oil idiot light doesnt light up on my dashboard?So what part would I ask for at the parts store?
