Is this a ruined axle?
Discussion in 'Technical' started by Acedmav75, Dec 13, 2014.
  1. Acedmav75
    Acedmav75 Member
    Miami Florida
    Maverick
    As i was removing the bearing and ring from this axle i some how managed to cut into the axle itself a bit :slap: Is this axle ruined?
  2. Craig Selvey
    Ummmm.....what were you cutting it off with?
  3. Acedmav75
    Acedmav75 Member
    Miami Florida
    Maverick
    a cut off wheel :( i did the other one just fine
  4. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    It'll be fine, seen many guys do this and never have an issue after.
  5. Mavman72
    If you plan on hitting the rear tires with some real torque...I would replace it. You have created a place for stress to concentrate itself and make the axle crack. You cut past the factory case hardened steel at the surface. If it were just a nick, it would be fine but its not.
    Heres a little tip for you next time you have to do this and dont have a press handy to help you...Only cut into the locking collar about half way. Then put a good sharp chisle in the cut and smack it with a hammer...The ring will split and you can remove it by hand.
    DC12VOLT likes this.
  6. Acedmav75
    Acedmav75 Member
    Miami Florida
    Maverick
    Thanks for the tip, thats what i was able to do on the other one and didnt have a problem cracking it off the axle but for some reason this one didnt want to get off that easily. Was hard for me to see how deep i was going, didnt think i was going that deep. Recommendation on a place to buy a new one? I seem to be having trouble finding one for an 8inch rear
  7. mav1970
    My 9 inch that came stock out of a Granada has 2 different length axles - I'm thinking that your 8 inch rear also does
  8. Acedmav75
    Acedmav75 Member
    Miami Florida
    Maverick
    mine is an 8inch but are both the same length
  9. mav1970
    I wasn't sure since I haven't seen my stock Maverick rear since I threw it away in 1990 :yup:
  10. Hairy W Bush
    Hairy W Bush Member
    Georgia
    1972 Maverick Grabber
    wondering if it can be welded and filed back down...
  11. Acedmav75
    Acedmav75 Member
    Miami Florida
    Maverick
    What would you consider "real" torque? just running a 302 with 3.55 gears.
  12. Bryant
    you should be fine. i see that on lots of axles that ive taken bearings off of.
    your axles should be different lengths.
    you will need to get a custom made axle or find a good used axle if you want to replace it. dutchman would be a good source for a new custom axle if you want to get one.
    blugene likes this.
  13. Acedmav75
    Acedmav75 Member
    Miami Florida
    Maverick
    thanks for chiming in! i really value your opinion and info. Im going to give it a shot and keep em. Hopefully i dont have to annoy you guys for awhile lol
  14. Bryant
    no annoyance here. this board is all about helping each other. if people didnt ask questions this site wouldnt exist. so dont hold back. ive also found the people like to just see what we are doing with our cars and love to see pics of what we are doing. so keep posting!
    Acedmav75 likes this.
  15. Rick
    Rick G8I operations
    Ocala, Florida
    I say let it eat, with any power I think the center will go before that.
    blugene likes this.
