It really sucks........
Discussion in 'Technical' started by Moneymaker 1, Sep 13, 2013.
  1. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    How's the engine bay room look? Maybe a carb hat with a pipe and a k&n on the end.. I know you got a cool looking air filter and all.. But sometimes functionality beats looks. I think it was scooper even went to a carb hat intake setup.
  2. olerodder
    olerodder Member
    NorCal
    What about a low profile air cleaner with the base dropped down 7/8" to 1-1/2". If you have the room this would enable you to maybe go with a larger element. Just a thought.
    http://www.knfilters.com/racing/14inch.htm
    http://www.summitracing.com/parts/aaf-all26092
    Don't remember what carb you are running, but if it has an electric choke you can only use a 7/8" dropped base.
    Just read the first post you did.....................if the air cleaner is "caving in"...........means you are pulling the cleaner down with vacuum, and
    either your element is too small or is it a paper element..................paper elements do hurt HP/TQ...............................IMHO
  3. olerodder
    olerodder Member
    NorCal
    Just a thought, do you have a vacuum gauge? If so, hook it up and see what the motor is doing with air cleaner on and you rev it up...........may prove interesting..................???
  4. Moneymaker 1
    Panama City Florida
    Thanks for all the suggestions so far guys, it's nice to have so many great minds working on this problem, I have given myself a headache today what with all the B/S about the master cylinder, I will check out the suggested solutions prolly tomorrow at PepBoys.
  5. mrmalina99
    mrmalina99 Member
    Belfair, WA
    1973 Maverick
    Maybe get something that will help "force" the air in? (y)
  6. lm14
    lm14 Member
    Iowa
  7. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    I know my AFR gauge drops 2 tenths when I put the air cleaner on vs without it and that's with a 2 1/2" x 14" K&N element in a drop-base Moroso housing...
  8. 71gold
    my dyno Guy said mine made 15 more HP with the breather off...he also said I could get 10 of that back with a K&N filter (that I now have)...:yup:
  9. rthomas771
    How much HP did you say you lost with the A/C on?
  10. 71gold
    that was too much to even believe and I was there...:yikes:
    but strange enough it didn't loose any with the windows down...:hmmm:
