Junkyard 5.0 update
Discussion in 'Technical' started by starsky74, Mar 28, 2009.
  1. baddad457
    The cover on the left is the one used on the 88-93 T-Bird/Cougar, 94-95 Stang and the 96-2001 Explorer/Mountaineer.
  2. bradleygt
    bradleygt Member
    grand rapids michigan
    1970 maverick
    you will need a new balancer to the one with that cover is 3/4 inch shorter than the one for older cover
    brad:)
  3. Joe Dirt
    thats great!
  4. starsky74
    starsky74 Technician
    Hackberry Louisiana
    yeah, i have to replace it anyway, the frt seal wore a nnice groove in the old one! i think they are the same though, i compared it to one i have for a 89 f 150, the pulley on the cougar balancer is flat against it, not so on the truck balancer. either way, im using all my factory brackets and pulleys until the 331 comes (y)
  5. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    I have an almost new cover like the one on the left. Came off an EFI 351W Bronco. It does not have the dip stick hole or a boss for the fuel pump. I also think it may be a reverse rotation water pump as it had serpentine belts.
    I have done several 302/5.0 swaps and there are several differences like you are finding. Plus the absence of the boss for the Z bar ball.
    It sure can be fun.
    clint
  6. starsky74
    Hackberry Louisiana
    went and got all new gaskets today, and a new water pumpa.... still searchin for an oil pan and pickup!!! :biglaugh:
  7. Dan Pearce
    Dan Pearce Member
    SC
    I'll sell you the engine out of my '72 Grabber. It needs to be reassembled. Most machinework is done.
  8. baddad457
    Both the oilpan and pickup tube can be bought new at your local parts house. I would at least buy the pickup tube new, that way there'll be no surprises from junk in an old tube.
  9. maverick75
    Jegs or summit has Chrome Oil pans for like $40, you know our cars like sum Bling Bling haha j/k
  10. thewest
    thewest New Member
    tucson az
    1972 ford maverick
    power steering
    how do i make my 72 maverick have power steering?
  11. starsky74
    Hackberry Louisiana
    yeah, i was gonna get a NEW pick up, i have a new oil pump though. i bought one of them chrome pans from summit for my first mav bc of the price. it was trash, none of the friggin bolts lined up right. i could bolt one side down, the other rail would be a 1/4 inch off!! so im not going that route again lol!!!!!
  12. baddad457
    If you had managed to get it bolted in place, you'd have then experienced the oil leaking qualities the chrome pans (and other parts) exibit.:thumbs2:
