Junkyard motors! What to look for?
Discussion in 'General Maverick/Comet' started by Alex129, Sep 23, 2017.
  1. Alex129
    Alex129 Member
    Missouri
    '72 Maverick
    Good day everyone!
    So, I'm in the market for a 302 block. I'm finally getting ready to ditch my tired 200ci, and want to build a nice street machine that would see the occasional track day. End goal is to stroke it to either 331 or 347 and have it making 380-400 rwhp carbureted (is that a word?), which I think would strike a nice balance between fun and practicality. I live near a pick-n-pull with oodles of Ford V8's. Any tips on picking a good motor? I know that some 302's have varying characteristics, like firing order, etc. Will any of those things matter if it's getting worked over for the stroker kit? Also, what are some tips for picking a motor that won't end up with hidden cracks, rust, etc.?
  2. Mavman72
    Any one of em may have hidden damage/rusr...Grab one that's still in a vehicle. 94/5/6 ford exploder/mountaineers have roller 302s in em.( good place to look) or mustangs, of course. Find something that's been hit in the rear/rolled over. If its solid and straight...Its in the junk yard with a bad engine/trans.(Usually)...
    Alex129 and junrai like this.
  3. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Check for milky oil or coolant either is a bad sign.
    Alex129 likes this.
  4. 71gold
    if you are going with aftermarket heads, any roller block should be good...JMO
    Alex129 likes this.
  5. Krazy Comet
    Dismal Swamp
    Basically a roller block is a roller block, makes no difference if it was grandma's Grand Marquis, your uncle's Town Car or a Mustang, Explorer, T-Bird etc.... In other words were in everything(though not all had roller cams installed), from mid '85-up...
    Good for approx 450-500 crank Hp before you run the risk of it splitting into two pieces... For a high Hp stroker that really is going to be beat on, a Ford Racing or aftermarket block is a better choice...
    As far as which one, cars that were less likely likely to be abused is usually a better choice...
    Alex129 likes this.
  6. RMiller
    Kennewick, WA
    Probably the best advice right there!
    Alex129 likes this.
  7. Maverick Dude
    Maverick Dude Member
    Cranbrook, BC Canada
    Type in roller block in the search function for more info on them. If you're planning on pulling an egine from Pick and Pull it might as well be a roller. That way you can run a modern roller cam. :2cents:
    MD
    Alex129 likes this.
  8. skipsgrabber
    skipsgrabber Should've had wrenches instead of hands
    lower alabama
    1972 maverick grabber,1979 F-150 4x4,1957 Studebaker Silver Hawk,1942 Ford Coupe,a boat,39 JD "H",And a bunch of JD garden tractors
    I would lean towards an exploder 302,or any 5.0 HO... Be wary tho,they don't have the boss for a z-bar pivot/column shift linkage bracket,and the GT40P heads are a pain to get headers for in a Mav,from what I hear... There are 5.0's in town car/grand marquis/crown vics...Some Thunderchickens had HO 5.0's too... Some years ago I put a 90' town car 5.0 in my cousins 85' mustang to replace the 3.8... Fit like a glove,but even with the v6 gears,the combination of heads pistons and cam,it's an absolute slug... Only slightly faster than the v6,and very thirsty... It has the E5SE heads,dish pistons,and standard 302 firing order... Be fine if you were gonna build it tho...
