Just Bought First Car Need Help
Discussion in 'New Members Forum' started by Keanu Gutierrez, Apr 24, 2015.
  1. Keanu Gutierrez
    Keanu Gutierrez Member
    Connecticut
    1971 Ford Maverick
    Hey guys, I just bought a 1971 Ford Maverick as my first car with its exterior in mint condition. The interior is a little worn but nothing major. I'm mostly concerned with the minor maintenance issues and need help/advice with what I should do. I want to convert my drum brakes to disc and have no idea where to start. And I also have an exhaust manifold leak that I want to take care of ASAP. As you can tell I'm not that experienced on getting hands on with cars but with a little bit of help I'm more than willing to learn so any advice is much appreciated. Thanks
  2. mojo
  3. Ryan Whiteside
    Ryan Whiteside MCCI SC State Rep
    Upstate, South Carolina
    1969.5 Ford Maverick 302
    I run granada discs up front and put an explorer 8.8 rear that already has disc brakes in mine. Night and day on the stopping power and maintenance. Aftermarket disc setup would definitely be nice but pricier according to which company you went with. Really up to what you want to spend.
    Keanu Gutierrez likes this.
  4. 71gold
  5. Paul Masson
    1971 Grabber
    :Welcome: from Atlantic Canada! If you are lucky, and find a 1976 or 1977 Maverick or Comet parts car, they would also have front disc brakes. They were optional in 74/75. These would be the exact same brakes as the 'Granada/Monarch" brakes. Does your car have 5-lug wheels? Is it a 6cyl car or V8? If your car is currently a 4-lug, 4-drum car, then converting to Maverick front disks will require 5-lug wheels and most likely (although not mandatory) a 5-lug rear end assembly. The 5-lug axle bearings are larger and will not fit your housing, so you'd need a complete unit.
    Good Luck!
  6. z28th1s
    Lynchburg, VA
    Welcome to the forum!
  7. JoeB
    JoeB Member
    Stowe, PA
    71 Maverick, 72 Comet GT
    Welcome form SE PA
  8. Hotrock
    Munroe Falls, Ohio
    Welcome to the site from northeast Ohio!!!! :tiphat:
  9. Keanu Gutierrez
    Connecticut
    1971 Ford Maverick
    I don't want to burn a hole in my wallet spending money on converting the brakes. I know you get what you pay for, but I rather just spend as little as possible on exactly what I need. Don't plan on paying someone to do the conversion for me either I rather just learn how to do it myself. Any suggestions on what manufacture set up I should consider?
  10. Keanu Gutierrez
    Connecticut
    1971 Ford Maverick
    It's a 6 cyl and a 4-lug. Just wondering, would it be necessary to change all 4 drums to disc? Or could I just change the front end to disc and leave the drum brakes in the rear? I heard there's a lot of newer cars that use that method and figured there can't be much of a difference for an older car like mine using the same method. Am I wrong?
  11. mojo
    U can leave the rear drums and just do the front convert. Post #5 pretty much gave the answer to the question. My car has Granada frt disk and 10" rear drums. It had the conversion done when I bought it from a previous owner. A lot of the cars before 74 had the conversion to frt disk. A lot of folks on the forum have also done a rear disk conversion. The question on whether or how much difference/better the performance, will have to be addressed by some of those who have made the change. I assume there is an improvement - reason some have made the change.
  12. Keanu Gutierrez
    Connecticut
    1971 Ford Maverick
    Yeah that's what I figured, I was hoping on only having to make the switch to the front end anyways. As far as performance goes, it doesn't matter to me as long as I'm driving smoothly on the road without rear ending anyone hahaha but thanks for your input buddy I appreciate the help
  13. Paul Masson
    1971 Grabber
    I only mentioned the rear end, because I figured you wouldn't want 5-lug wheels in the front and 4-lugs in the back. It may make wheel selection a bit interesting. And to reiterate: even though your rear differential is an 8" Ring and pinion, the 5-lug axle shafts will NOT fit inside the 4-lug housing due to axle bearing dimensions being larger on both the ID and OD.
    I would try and source a complete 5-lug rear end. Drums are fine out back.
  14. Keanu Gutierrez
    Connecticut
    1971 Ford Maverick
    That would make wheel selection very interesting lol.
  15. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    You should get a front disc setup from a '74-'77 Maverick or a '75-'80 Granada, and get a 5-lug rearend from a Maverick, & swap it all onto your car. You'll then need 5-lug wheels. Drum brakes on the rear are just fine, but you'll want a all for wheels to be 5-lug. It would be ideal to find a "parts-car" Maverick with those items and buy the whole car, since those parts are quite popular and don't stick around long in junkyards.
