key cylinder
Discussion in 'Technical' started by axl4u2000, Sep 23, 2002.
  1. naccaatt
    naccaatt New Member
    Southern Oregon
    Ingnition switch
    Anybody know where I can find instructions or schematic on removing the switch? A mechanic friend told me that if the key cylinder is turning fine when its out, that it might be the switch and I might want to check it. I also read in here that it could be gummed up, either way, the switch doesn't appear obvious to me. the only thing I see is to pull out all the guts on the top side of the column (as shown in the "key cylinder" picture earlier).
  2. PaulS
    The switch is at the base of the steering column - only the key cylinder is at the top.
  3. naccaatt
    naccaatt New Member
    Southern Oregon
    Ignition Switch
    By " at the base of the column" do you mean under the assemblies (blinker control and hazard lights) shown in the picture attached?
