Key stuck in ignition
Discussion in 'Technical' started by Deerhog, Apr 5, 2017.
  1. Deerhog
    Deerhog Member
    Texas
    1973 Mercury Comet GT
    I don't care it is looks right visually, I just want to get this car on the road then worry about cosmetics.
  2. Deerhog
    Deerhog Member
    Texas
    I found a 73 cougar/Mustang column. Would that work?
  3. Deerhog
    Deerhog Member
    Texas
    Is there anything else that I need to take off to get the column apart besides these two bolts and the little clip around the steering shaft? Anything?
  4. Craig Selvey
    I believe there is a bolt inside the "hole" on the side of the collar pictured here.
  5. Deerhog
    Deerhog Member
    Texas
    I was able to fix the problem and I also got the car running after sitting for 15 years! Now I can finally move on with the project.
  6. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Don't leave us hanging....what was wrong with it????
    Krazy Comet likes this.
  7. Deerhog
    Deerhog Member
    Texas
    Kind of hard to explain. My car is not a column shift so I had eliminated this as a problem but the part that rotates if I did have a column shift was stuck in a position that wouldn't let the lock assembly move past it. That's what I felt it catching on. I was able to get the column apart thenot since it was stuck I took a sawzaw and cut off the piece of metal it was hanging on.
    My next problem is trying to find ALL of the rubber suspension parts so if you have any info on that let me know.
  8. 71gold
    when I did my column to floor shift conversion I had to secure the lever in the park position so it would let the key turn to the lock position. how I found this was I was coming up to my driveway and the steering wheel locked coming down the road...:yikes:
  9. rthomas771
    When I went from auto on the column to 5-speed manual I had to tie the lever up also
