Leaf Spring Specs
Discussion in 'Technical' started by SR71 blackbird, Apr 14, 2021.
  1. SR71 blackbird
    SR71 blackbird Member
    Oregon
    Ford Explorer
    I looked for this earlier, but was unable to find. Does anyone have a source of specs for leaf springs for a '73 Grabber? Specifically, am looking for the front eye bore diameter and also the shackle specs. Am trying to find the specs to see if the Del A Lum bushing kits that Global West sells will work on my car. They do not sell the kits specifically for Mavericks, but another Ford or Mercury product may fit if I can find accurate specs. If I can find specs without taking the whole thing apart, that would be great!
  2. rthomas771
    According to the Master Parts Catalog the front leaf spring bushing is part number C4DZ-5781-C Same part used on 64-70 Falcon, Mustang small block up to '69, 65-71 Fairlane, 75-79 Granada, 71-73 Pinto
  3. SR71 blackbird
    Oregon
    Ford Explorer
    Thanks Jeff. Much appreciated. In that catalog, is there any spec on the shackles?
  4. dyent
    dyent Member
    vancouver bc
    Back in 2015, I purchased Global West Del-a-Lum bushings, front eye is same as 65-70 Mustangs (RB82) and you use the rear shackle set up from 67-70 Cougars, which are 1" diameter here is the complete leaf spring kit, which
    has both front eye and rear shackle, well worth it!
    http://search.store.yahoo.net/yhst-...x=0&y=0&.autodone=https://www.globalwest.net/
    Since then, I have worked with Doug at Global and now have their "spherical bearing" set up on my leaf springs....
    PM me if you need more information etc........
    David
  5. SR71 blackbird
    Oregon
    Ford Explorer
    Thanks David! That is just the confirmation I was looking for! Much appreciated!
  6. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    David, what is the "spherical bearing" setup?
  7. dyent
    dyent Member
    vancouver bc
    I worked with Doug at Global West and I had a new main leaf made to install this set up..........
    David
