leaf springs
Discussion in 'Technical' started by JAYSMAV, Aug 23, 2013.
  1. Rando76
    Rando76 Member
    Claremore, OK
    Sorry, I missed this comment when I posted about General Spring in KC.
  2. JAYSMAV
    JAYSMAV Member
    Ohio
    '73 Comet 302 LDO auto, '70 Maverick I6
    I like to try new things I've never done, I don't know about better :).
  3. rthomas771
    All you need is a hammer to bend the tab over.
  4. Dale74Mav
    Dale74Mav Member
    Atlanta, Illinois
    1974 Maverick
    Randy, I have a couple of questions....were the springs a direct replacement.....no problems with fit. ? Did they change the heighth of the back of the car? I looked at the springs at general spring, they had more leafs than my 74 two door. Thanks......Dale
  5. 71gold
    if your stock springs have lost their arch, then they will raise the back up to stock height...:yup:
  6. Rando76
    Rando76 Member
    Claremore, OK
    The springs were a direct replacement with no problems whatsoever. Buy some new eyelet bushings too, they aren't expensive. I was replacing old, worn out 3 leafs. They raised the Grabber to what I expect stock would be, which I was happy with. My 73 is lowered and the rear would bottom out. They made a HUGE difference in the ride. After the new springs, no more of that!
    I talked to a spring shop in Tulsa before ordering the springs. It was much cheaper for me to buy the new springs than have mine re-arched.
  7. Dale74Mav
    Dale74Mav Member
    Atlanta, Illinois
    1974 Maverick
    Thanks Randy, just looking for a good supplier. I have heard or read of a few folks that were not happy with springs from JC Whitney, thanks for the information on this place.........Dale
  8. Rando76
    Rando76 Member
    Claremore, OK
    I should have clarified, I have both. My first set is from JCW. I like them fine, it just took too long to get them (they were backordered). The second set I ordered was with General Spring in KC. I think they are a better spring for the price. The JCW spring is fine, but for about the same price, General Spring sells a shot peened spring - it looks pretty and it's local! JCW springs are sourced from John R Spring, who imports them.
    Also, both sets I bought are 4 leaf.
  9. mojo
    I have the General springs on my Comet. For me, they were vry stiff ride. After, abt 2 yrs of tolerating "what I consider" a bone jarring ride; I finally removed the bottom leaf. I wish I had know B4 I installed them on the car -- I wud have removed the leaf. The car is much more pleasurable to drive and only lowered the rear abt 3/4in. After getting some info frm "71Gold" who had the same issue - I removed the leaf - One of the best mod's I've made to the suspension - If not the entre car.
  10. Rando76
    Rando76 Member
    Claremore, OK
    Interesting that we had such different experiences with them. Maybe they will make a 3 leaf set if asked?
