Leaking fluid from steering system
Discussion in 'General Maverick/Comet' started by rag9836, Jan 31, 2016.
  1. rag9836
    rag9836 1972 Comet, 67K
    Riverside, CA
    Comet
    I am leaking fluid from the Power Steering pump lines (pressure and return) and it looks like they all need to be replaced.
    While I am doing this, I am wondering if the control valve is good (how can you tell) and if I should replace that and the power cylinder; it's all the original 72.
    all the parts from the local auto store are going to be roughly $400. That said, has anyone gone through this...any upgrades that should be taken into consideration now? Getting the control valve out seems like the most work.
    Thanks
  2. 71Mavrk
    71Mavrk Member
    Nevada
    This guy sells some good complete rebuild kits. He might be a PIA to get a hold of though. Get a new brass sleeve for the ball joint and the aluminum nipples for the hose connections.
    http://www.stangerssite.com/partsindex.html
    Rock Auto has good prices on the hose and rebuild kits from Gates but they don't have the sleeve and nipples.
    Rebuilds are not difficult. I did mine and have no leaks or problems.
    Probably a good time to look at the tie rod ends and idler arm.
    Micah
  3. Krazy Comet
    I bought new Gates hoses from ebay as well as cylinder & valve rebuild kits, never did one prior but it isn't that difficult...I don't remember what I paid for all the stuff but wasn't much over $100...
    I agree on checking out other steering components as well... My car was a 65K mi orig, most all of it was worn out... I replaced everything that moves, incl upper & lower control arms...
  4. Paul Masson
    1971 Grabber
    image.jpeg image.jpeg I rebuilt my control valve and cylinder. Not a bad job, just take your time. I got all my kits and hoses through Rock Auto. I believe the kits were AC Delco (I know...).
    I have ZERO leaks and she's as tight as a drum!!
    I replaced ALL of my steering and suspension. My car has 20,000 on the clock...
    71Mavrk and Krazy Comet like this.
  5. Red1972Grabber
    Northern California
    Make sure your hoses are on correctly. If you criss-cross them your steering wheel will violently spin back and forth. Ask me how I know?:eek:
    palser64 and William623 like this.
  6. William623
    Orlando
    1973 ford maverick grabber
    Did that too...scared that crap out of me!
    palser64 likes this.
  7. rag9836
    Riverside, CA
    Comet
    Thanks guys! Going to tackle the job this weekend!
