leaking transmission fluid from throttle on side of transmission.
Discussion in 'General Maverick/Comet' started by russellgaspard, Jul 21, 2014.
  1. russellgaspard
    russellgaspard Member
    united states
    1973 Ford Maverick 250 Inline 6
    Where the throttle bar connects to the transmission there is fluid leaking out. I am assuming its a bad gasket but can anyone tell me the name of the gasket and tell me how I would change it? I cant figure it out. I tried looking in the chilton guide but couldnt find anything. It's leaking from where the red arrow is pointing. Heres a picture of what im talking about:
  2. Krazy Comet
    Dismal Swamp
    The rubber "O" ring on shaft is leaking... Will require removal of pan, valve body and linkage from inside the transmission...
  3. 71gold
    there is a seal just above the arrow...it's called the...shifter shaft seal...:bouncy:
  4. russellgaspard
    united states
    Thank you! :)
  5. scooper77515
  6. 71gold
  7. scooper77515
    It didn't take 40 years. Mine has always had a puddle of fluid under it.
    I just figured all C4s leaked like that.
    After swapping the seals a couple of times, and still leaking, I looked around on the internet and came across this fix a couple of times.
