Leaks, LEAKS and MORE LEAKS!!!!
Discussion in 'Cosmetic' started by lilacso, Jun 16, 2011.
  1. lilacso
    lilacso Member
    Walden, NY
    1976 Maverick
    I have had the windshield installed 3 times, siliconed a crack above the drip rail where the inner and outter roof join together, plugged up 4 holes in the firewall, ran a hose through the cowl vents (no leaky cowl) - and still have a trickle at a seam way up under the dash. I ran the hose over the front passenger side fender and water started trickling in. I stuck my hand way up behind the dash and just started pulling out handfuls of rust.
    I'm getting closer to finding the leak. But once I find it on the passenger side, then I have to start on the driver's side.
    THIS IS DRIVING ME NUTS!
    Any advice??
  2. 71gold
    "THIS IS DRIVING ME NUTS!"
    stop looking...:huh:
    or...pull the heater box...:yup:
  3. darren
    The seam sealer on the A pillars down to the torque box area dries up and cracks real bad. Never mind the lousy job they did putting it on in the first place. You'd have to pull the inner fender shield and likely the fender to get at it and fix it properly.
  4. lilacso
    lilacso Member
    Walden, NY
    1976 Maverick
    Yep that's what I was afraid of. I'm not too confident that this is a job for me to do... but a friend of mine said he might be able to work on it during the winter. I guess all I can do is hope for a very minimal amount of rain til October....
    and out of all the silly smilies, there is nothing to represent ::fingers crossed:: LOL!!
  5. injectedmav
    injectedmav Member
    Georgia
    The fender isn't too bad to do, even for a novice, just tape all of the edges so you don't scratch anything and having the extra set of hands helps quite a bit.
  6. mavtricks71
    mavtricks71 Member
    Let me tell you about a Windshield experiance i had... I bought an Aftermarket brand new windshield about 4 years ago and had it installed and uninstalled 4 times... turns out the windshield was smaller in length and diameter then the original, even ordered 2 different ones to make sure it wasnt just a bad one... went and bought an original carlight windshield no problems.
  7. don graham
    If you put your hand behind the dash and pulled out handfuls of rust, I'd bet your cowls are rusted. Major job there. Do a search for cowl repair.:mad:
  8. MaverickLVR
    MaverickLVR takes longer then you think...
    Grand Rapids, Michigan
    1976 Maverick Stallion, 1967 Olds Delmont convertible, 1999 Harley FatBoy
    dont drive in the rain anymore :)
  9. simple man
    simple man Member
    Bunnell,Florida
    Good advice! My left side is bad, I've just been lazy and haven't fixed it yet. I keep the car under roof, so it's not a big issue to me. I have been caught in our Florida downpours before, so that's why I keep a towel to throw down on the floor when it leaks!:)
  10. lilacso
    lilacso Member
    Walden, NY
    1976 Maverick
  11. Clintd
    Clintd Member
    Parlin NJ
    75 maverick, 89 Cougar (sleeper), 04 Superduty and a 87 Cougar
    If your ever in the central jersey area I'll help you track down the leak. I'm assuming your the one I texted about the windshield glass on Craigslist?
  12. lilacso
    lilacso Member
    Walden, NY
    1976 Maverick
    Yep, that's me! I used to work in Rockaway - So I know it takes an hour and 15 minutes to get THERE. How much further are you? I think I was taking exit 114 off 287. I could be wrong on that number though.. its been a while.
  13. bmcdaniel
    bmcdaniel Senile Member
    Same thing here, I've had new rubber gaskets installed front and rear and both resealed by Safelite. In a hard downpour water dribbles from the top center of the windshield/headliner and the back glass/headliner. Like above, I carry a couple towels...
  14. Cowboiup1979
    Cowboiup1979 Member
    Louisville Kentucky
    1976 ford maverick 302v8
    Allwyas nice to hear about horror stories, knowing i am in for a windshield replacement soon myself.... who would you guys recommend in the Kentucky area (louisville)?
    My current windshield has a massive crack running down through the middle behind my rearview, and across the drver's side
  15. Clintd
    Clintd Member
    Parlin NJ
    I have no idea. The shop I work at is in Neptune and its exit 100 off of the parkway.
