LED instrument lights
Discussion in 'Technical' started by EFIMAV, Aug 19, 2013.
  1. z28th1s
    Lynchburg, VA
    Yes, they will.
  2. walkejf
    walkejf Member
    Waco, Texas
    1972 Ford Maverick, 1970 Ford Maverick, 1977 Ford Maverick 4-door
    how many bulbs are in the instrument cluster that the leds can replace?
  3. z28th1s
    Lynchburg, VA
    There are 10 bulbs in the back of the instrument cluster:
    (1): High beam indicator
    (2): Turn signal indicators
    (4): Warning lights (temp, oil, brakes, battery)
    (3): Instument cluster general lighting
    I would say just replace the (3) general lighting bulbs with the LED's and leave the standard 194 bulbs in the other spots.
    That is what I'm going to do. I ordered LED bulbs today from superbrightleds.com. I have bought LED's in the past for my later model Mustang from them and have had good luck with their bulbs.
  4. rthomas771
    With my LED's....I can turn the knob about a 1/4 turn without killing the LED's.
  5. walkejf
    walkejf Member
    Waco, Texas
    Awesome, thanks. Im going to switch out my cluster lights and see if I can read the gauges at night now =)
  6. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Thanks for this info. And I agree, just replace the general cluster lighting. The other stock bulbs are never on full-time and easy to see.
  7. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    But they have so many different ones. Which ones should I get?
  8. z28th1s
    Lynchburg, VA
    You're welcome!!
    That is what I figured too!
    Here is a link to the page where I bought mine.
    http://www.superbrightleds.com/cat/...-maverick--instrument-general/20-737--292738/
    These are the ones that I got: 194 LED Bulb - 5 SMD LED Wide Angle Wedge Base
    I got them in 'Cool White'.
    They are the ones that are listed at the top of the page. They are #1 on the list of bulbs.
  9. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Thanks. I just ordered some. I was tempted to order green, but those probably wouldn't be bright enough.
  10. z28th1s
    Lynchburg, VA
    You're welcome!
    I also thought about getting the green, but I figured the white would be the brightest and make the gauges easier to read at night.
  11. mavrod75
    mavrod75 Member
    Warwick, NY
    1975 ford maverick
    The white face gauges look awesome.. how hard is it to pull the cluster to install?
  12. walkejf
    walkejf Member
    Waco, Texas
    whitegauges also sells LED replacements for the cluster bulbs. I purchased the whitegauges kit with the replacement LEDs and I am very happy with the overall product. There are 4 bulbs that I would change out in teh instrument cluster.
  13. walkejf
    walkejf Member
    Waco, Texas
  14. youngcarguy
    youngcarguy Member
    randolph co. N.C.
    1970 maverick
    the easiest thing I have found is placing two 3" led strips in the gauge cluster there is plenty of space between the gauges and lens. the strips are only $15 at your local parts store and you can pick any color you want and it definitely lights everything up!!
  15. captainmack
    captainmack Quad Door
    They are called T- 3.25, or T-3-1/4" Wedge Base bulbs.
    I found the #158 bulbs in my car. They are barely bright enough at night turned up all the way. They are also the 2nd dimmest. #161's are a joke.
    #168 4.9 watts Brightest possible meltdown
    #193 4.62 watts Next Brightest, also iffy on heat
    ____________________________________________
    #192 4.3 Watts third brightest and reported to not melt
    #194 3.78 Watts, real close in watts to the 158's why bother
    #158 3.3 watts Stock and not bright at night
    #161 2.66 watts dont bother, right???
    Now I also found LED replacements!
    http://www.superbrightleds.com/cgi-b...ini-wedge.html
    The brightest that would fit are the WLED-WHP9-T but they are only 35 Lumens, and the 158 bulbs I have now are 32 Lumens..the LED bulbs are Like $15.00 each...
    I installed the 168's and the reason is I have LED lit AutoMeter guages on my modified dash pad and they are way too bright when the dimmer switch is turned up all the way. So, when I turn down the dimmer to dim the instrument cluster, I expect the Auto Meter's to be comparable in brightness.
