Left turn signal/break issue
Discussion in 'New Members Forum' started by RicketyMaverick, Jun 5, 2017.
  1. RicketyMaverick
    RicketyMaverick New Member
    Los Osos, CA
    Ford Maverick
    (1975 Ford Maverick)
    My left turn signal and brake light are both completely out. When I hit the switch the interior light comes on but freezes, without flashing. The taillight itself is dead, however. Now with my hazard lights, they work perfect on the inside, but once again the actual taillight is dead.
    Is this a ts switch problem? Could it be the bulbs? Does a
    nyone have similar issues to this?
  2. Krazy Comet
    I assume the front is lighting?? If it's bulb and socket/ground connection are OK it should be, as it and dash lamp are on same feed... For rear if you haven't tried the bulb, it's the first thing to do...
    RicketyMaverick likes this.
  3. rthomas771
