Let's identify a motor
Discussion in 'General Maverick/Comet' started by SamsDad, Mar 31, 2014.
  1. MSmithPDX
    MSmithPDX Member
    Portland, OR
    I was just saying, I hate cleaning up used parts. If someone else wants to clean them up, and they did a good job, I'm happy to consider purchasing them. I'd just prefer new when I can find it.
  2. groberts101
    groberts101 Member
    Minneapolis, MN
    I won't even get into the reasoning as to why sludging occurs since I'll end up exceeding the character limit to do it.
    I will say this though. This is cast iron.. not aluminum. If anyone thinks that many of the core motors or rebuilt long blocks they are buying looked much different than this motor when they were sitting in junkyards and brought in on pallets?.. they're being very naïve. In general.. people take decent care of newer cars up until such time that they start funneling too much cash out of their bank accounts. From there.. it's all downhill and things don't get done on a schedule very often.
    IMO, so long as a motor has been fully mag'd and passes inspection?.. I'll take one that's been subjected to heavy thermal cycling.. over one that's been "babied every day of its life".. any day of the week. It's called "seasoning" and gives more precise final machining.. that stays put longer.. over an engine that's been babied and never overheated or frozen in -50 degree weather. Hell.. many shops still dip, bake, broil, and rotisserie blocks too.. and that's a MUCH hotter environment overall(+750 F) than an engine block will ever see during an overheat situation. Sure there are hotter "spots" created during an engine failure.. but overall they are never discarded because of that fact alone.
    If you're machining everything again anyways?.. and you should because the factory tolerance allowance sucks spaghetti sauce.. what does it matter?
  3. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    Sludge doesn't matter if you rebuild it use the block- cam retainer buy new performance heads aggressive cam you have a ho motor if you use Valvoline the life of the motor it will not look like that Valvoline forever:yahoo:
  4. Krazy Comet
    If you use Walmart's Supertech and change it once in awhile, it won't look like that...
  5. groberts101
    groberts101 Member
    Minneapolis, MN
    or for that matter.. even Quaker state. :biglaugh:
  6. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    So true regarding "seasoned" blocks. I have seen people pay bucks to shot peen new rods to relieve internal stress in the castings.
  7. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    no Quaker sludge for me but oil is oil as long as it is has the API stamp its basically all the same super tech - Havoline- gulf pride multi g- change it regular oil is the life of the motor except Quaker sludge:rofl2:
  8. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    it all depends on the budget you can spend as much or as little as you want new or used if its machined and put together correctly it will last a long time unless you use Quaker sludge:rofl2:
  9. Krazy Comet
    Calling it Quaker Sludge just shows how little you really know about modern oils...
  10. Dave B
    Didn't you already say that? :rolleyes: We don't care, we'll all call it whatever we want.
  11. mojo
    I used QUAKER STATE for years -- never had any issues with it. I don't think they cud have survived all these years making a substandard product. They hve won a lot of
    NASCAR races over the past 20 yrs. I think that is no small feat by most standards.
  12. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    oil is oil is oil and I will say it again QUAKER SLUDGE QUAKER SLUDGE QUAKER SLUDGE :taz: if it says api then its good oil even QUAKER SLUDGE
  13. Lzoesch
    Lzoesch Levi Zoesch
    Spokane, WA
    My 302 (306 now) 5.0 motor has XXX in the valleys, and runs off the HO fire order.. :huh:
    Just read in a previous post that XXX motors are Roller ready? Good to know...
  14. Krazy Comet
    I dunno the date, but std lifter only blocks were discontinued sometime in the '80s, would make no sense to cast two different blocks when the roller block can be used with either type lifter... In addition to the XXX block there are YYY versions that are also roller...
    I've seen a '85 truck block that was cast for roller lifters(hold downs for spider were not machined) but had a flat tappet cam installed... That one came from a friend's truck that he bought new, we know it's orig...
    Firing order is totally cam controlled, the Lo-Po '86-'91 5.0 used in T-Birds('86-'88), Grand Marquis, etc had roller cams and used the std 15426378 firing order, I've owned three of those engines... Block, crank and rods are exactly same as ones used for HO engines... Pistons are flat top because of the E6 swirl heads used on those versions...
  15. SamsDad
    SamsDad Member
    Little Rock, Ar
    1973 LDO turned Grabber Clone
    Lmao
    I just got online for a few and was catching up and I got to laughing a good one at the "thread drift".
    What started out on one basis has what could be 3,4 hell maybe even 5 diff thread topics in this one thread....it's all good cuz I'm ADHD so it makes perfect sense to me:rofl2::rofl2:
