lighter weight master cylinder
Discussion in 'Parts Interchange' started by safado, Feb 9, 2015.
  1. safado
    safado Member
    West Phoenix, AZ
    As some may know, I am trying to make the comet as light as possible.. and in doing so am converting over to manual brakes.... I bought a bendix master as it comes with the pushrod and noticed how massive it is compared to masters in newer cars... So i was curious if anyone has outfitted another master onto their cars that are aluminum or just lighter in weight besides say a wilwood master...
  2. 71gold
    I have a...Strange...in my car.
      File size:
      116.6 KB
      51
  3. safado
    safado Member
    West Phoenix, AZ
    Besides the lines, does it bolt right in?
  4. tody
    tody Member
    cologne, germany
    i have a nineties ranger unit in my car, aluminum body with plastic reservoir. was a direct bolt in, besides the lines. i'm using it for 4 wheel disc brakes, though.
    junrai likes this.
  5. t.ramsey
    t.ramsey Member
    austin,tx
    both
    Tody, how is the pedal with the Ranger m/c? I went with a 15/16" manual unit from a Maverick and it's extremely hard.
  6. tody
    tody Member
    cologne, germany
    i used cardone 132532, pedal feel is very good
  7. t.ramsey
    t.ramsey Member
    austin,tx
    both
    Manual or power?
  8. tody
    tody Member
    cologne, germany
    manual, stock maverick disc brakes in the front, versailles rear with stock disc brakes in the rear.
  9. t.ramsey
    t.ramsey Member
    austin,tx
    both
    I have Crown Vic rears. Not sure if that would make a difference. Did you have any issues with the metric fittings?
  10. tody
    tody Member
    cologne, germany
    the metric fittings were at least one thing i could get easily over here in germany ;)
    i made my own short lines from the mc to the distribution block.
  11. junrai
    junrai Member
    rancho cordova ca
    I have this same set up using 4 wheel disk brakes
    it might weigh 2lbs full of fluid? it feels like its not there......a 1/2 gallon of milk is heavier
    the best part is you can buy one new for $42.00 brand new at autozone and they had it in stock
    works great on my comet gt
  12. mojo
    What abt cyl. push rod - it come w/ unit or reuse old one? What bore size works for ur setup - I have drums on rear?
    I just bought new MC "OE old style" but may not put it on -- wud like one of the newer style units. What fitting changes u had to make? Are there std. to metric adapters or do u have to cut and flare for the metric connection?
