Lighting Issues
Discussion in 'Technical' started by 1974Comet, Aug 7, 2012.
  1. vvr210
    vvr210 Member
    Vista,CA
    I bought my brake switch at NAPA last month for like 15 bucks
  2. 1974Comet
    1974Comet Enthusiast
    Kansas City, MO
    1974 Mercury Comet
    okay then, so i suppose the next purchase will be a brake switch then? I guess I'll see what i can do. And then what should i do to get the turn signals working once again? Anybody have any ideas?
  3. MICHAEL DAVIS
    MICHAEL DAVIS Member
    1973 Ford Maverick
    Fallow the wires/ 'disconnect the positive side to the battery and pic a light that didnt work and fallow the wires you have some difficulty when it comes to fire wall or interior im not saying tear the car apart but just pic a light and remove the batery cable and follow the wires for that light if your luck it will still have some color and you could trace it thru the difficult areas and Maybe find something like a broken wire.. Bad fuse,s bad grounds light bulbs do have a ground the bulb that is or there is relays that fail..Enjoy but remember to disconnect the battery when tracing wires im not a mechanic but safty allways...
  4. socalcomet
    socalcomet Member
    Menifee, California
    1974 Comet
    I had to replace my blinker flasher, it's separate from the emergency flasher IIRC. It's under the dash near the steering column (round, blue & hard to find).
  5. 71gold
    did you check the sockets to see if they are getting...power? (test light-volt meter)
    the tail lights ground through the sockets to the tail panel.
    my new tail light sockets came with a...ground wire made onto them. they were ran to a grounding bolt on the frame...:yup:
  6. Vinchez78
    Vinchez78 Member
    Columbus GA
    1973 mercury comet
    i know this is a very old post, but did you ever solve the issue with your turn signals? i too have that problem with my 73 comet, dash lights or signals dont work, and from what ive read, in order for me to replace the bulbs i gave to take apart just the cluster or the whole dash? i think ill start with checking the fuses first. any help for this newb would be appreciated, thnks!
  7. 1974Comet
    Kansas City, MO
    1974 Mercury Comet
    If I remember correctly, my issue was due to the flasher unit in the car as well some other issues with the light sockets. The flasher unit was separate from the hazards flasher and the rear left tail light socket was pretty beat up. I ended up re-wiring half the car anyway, but I do believe what fixed my turn signal problem was the flasher unit under the dash.
    Best of luck to you!
  8. Vinchez78
    Vinchez78 Member
    Columbus GA
    1973 mercury comet
    thanks for the info mate
