line lock
Discussion in 'Drag Racing' started by HOMERMAV, Aug 16, 2010.
  1. jmgford
    jmgford Member
    Iowa
    I have installed two of the Summit brand (which appear identical to a Hurst) with no problems.
  2. maverickmadness
    maverickmadness Member
    ala
    1973 maverick grabber, 1972 maverick grabber,1974 maverick grabber,
    ive used hurst with no issues, summit and jegs all worked fine the summit and jegs are way less expensive
  3. gestiva
    gestiva Member
    Birmingham AL
    1973 Ford Maverick
    ^This is one of the things on my list to buy.
  4. mavman
    mavman Member
    Arkansas
    Got a cheapie on mine. Has worked for many many years but it's also mounted far away from header heat. The Biondo one listed above is a good one...Biondo makes/sells a lot of GOOD stuff. The owner is a racer and uses his own stuff-which helps as far as knowing where/what to improve.
  5. maverickmadness
    ala
    at the strip with that 4 speed you will want it
  6. gestiva
    gestiva Member
    Birmingham AL
    1973 Ford Maverick
    ^I could have used it tonight! found out quick that holding the brake doesnt work well.
