liquid leaking into cab
Discussion in 'Technical' started by russellgaspard, Jan 15, 2015.
  1. Mel Moeller
    Mel Moeller Maverick Moe
    Twin Falls Idaho
    1971 Ford Maverick, Two 1973 Mavericks, 1974 Mercury Comet
    Sounds like a cowl rebuild to me. The reason I am saying that is that this is a common thing to go wrong with these. You may find the top hats or at least one are rusted out letting the water come in there.
  2. russellgaspard
    russellgaspard Member
    united states
    1973 Ford Maverick 250 Inline 6
    I'm positive its the rubber seal around the door. I can see where its leaking in. Its not the cowl.
  3. russellgaspard
    united states
    The seal is so old its flattened out in one spotand no longer makes contact wwith the door. I can even see through the crack when the door is shut
  4. Mel Moeller
    Twin Falls Idaho
  5. Mel Moeller
    Twin Falls Idaho
    And how did the water get down inside there?
  6. russellgaspard
    united states
    Inside where?
  7. 71gold
    and..."its radiator fluid that's leaking in the cab"...:huh:
    you may have two leaks...:yup:
