List of parts that interchange with the Maverick/Comet
Discussion in 'Parts Interchange' started by Stefan, Aug 21, 2007.
  1. Deanbeard65
    Deanbeard65 Member
    Tucson, Arizona
    1976 Maverick 2DR 302
    Great list very good master Stefan may the force be with you.
  2. Red Rooster
    Red Rooster 302 and C4 Rebuild done:)
    San Antonio, TX
    74 Comet GT
    Searching for the 2-Piece Z-bar
    5 month Search for a z-bar for 74" Comet 302
    There has been delays with getting the clutch equalizer/z-bar thru AutoKrafters or Melvin's (Conyers,GA).
    Can anyone help with a location of a pick-a-part or another manufacturer/distributor that may have one?
    Red Rooster
  3. ezdoes123
    ezdoes123 New Member
    NEPA
    I have a 1970 Ford Maverick. It originally had a 6 cylinder, but now it has a V8. Everything was changed as far as suspension goes, except it still has the original 4 bolt front end.
    I'd like to not only change it to 5, but install disc brakes. Can you tell me what would work on my car? Also, the gas tank has considerable corrosion, and I'd like to replace it, but I can't locate a Maverick gas tank. Are there any Mustang gas tanks, etc. that would work?
    Thank you!
  4. CaptainComet
    Welcome to the board.
    For front disc brakes most guys go to 74 and later Mav/Comet or first generation Granada/Monarch/Versailles.(pre-1981) Grab the entire spindle and it is a virtual bolt-in except that you have to use tie-rod ends that match the later hardware and you will want to change the brake lines. 73 Mavs had a disc brake option, but if I am not mistaken, those are 10 inch rotors and all the later ones are 11 inch, a lot more stopping power.
    Gas tanks ... later tanks are reproduced but not prior to 74. Those end up being very close to the rear valance. There also is a great tech article here regarding swapping in an early Mustang tank. The advantage of that is it is centered in the car and there is more room for dual exhaust.
    This board has a great search function and it is a wealth of knowledge.
    Also, go introduce yourself at new members ... :thumbs2:
  5. CaptainComet
    Rooster,
    The Z bar is specific to Mav/Comets. I am not aware of any repro'd at this time. Maybe if you posted in Parts Wanted, someone could help you out.
    Expect to pay ... :oops:
  6. mav1970
    Where in NEPA do you live?
  7. Jerry Hayes
    Jerry Hayes Member
    Cheyenne, Wyoming
    Hello,
    I am curious if the front fenders from a 71-72 Mercury Comet will work on a 70 2 Dr. Maverick?
    Thanks,
    Jerry Hayes
  8. rwbrooks50
    rwbrooks50 Member
    Forney Texas
    71 Maverick & 63 Ranchero
    Yep, they will work.
    Rick
  9. Ladylovecomet
    Ladylovecomet Member
    Pend'Oreille County in Washington State
    1971 Comet
    TonySir and Kenn like this.
  10. Jerry Hayes
    Jerry Hayes Member
    Cheyenne, Wyoming
    parts interchange
    Hello,
    I checked that interchange guide. There is some very helpful info. there. Thank you for sending this to me.
    Jerry:drive:
  11. predfan2001
    As far as the Mustang rear bumper question goes....I ran a 68 Mustang rear bumper on one of my old Mavericks. It looked fine to me but I think I had to modify the brackets a bit.
  12. justin has a 74
    kentucky
    thats just cool
  13. maverick75
    Those bumpers are about 1" wider on each side, but they do fit.
    I'm actually making my maverick bumper narrower to be more appealing to the eye.:)
  14. new maverick
    new maverick Member
    middlesex va
    maverick
    where can i find a rear for my 70 maverick
  15. mav1970
    I'm sure someone can help you out on the forum. There are quite a few members from the east central and southern states here. If you have the small 7 3/4 rear with the back bolt on cover, here is your chance to upgrade to an 8 inch rear.:thumbs2:
    You should also post this in the classifieds under "parts wanted" - you may get better results :yup:
