lite relay upgrade done
Discussion in 'Technical' started by 71gold, Dec 15, 2003.
  1. 71gold
    :D corbin, thanks for the info. if you would post it and all will know when they do the upgrade.i will swing by napa and check and see if they have any on the shelf..frank...:bananaman :bananaman
  2. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    Well, I got the ones I ordered from Napa, and I got the wrong ones shipped to me. They were too narrow to fit over the terminals on the headlights. Since I couldn't get any in time before New Years Day, I went to Ford, and they had some that I ended up using. They are little pig tails like the ones in the plugs you buy, but they had much bigger wire (around 14 - maybe a little bigger) These aren't specific for these plugs, so a little "massaging" needs to be done for them to clip in. The little tab on them is longer than the ones in the ready made plug, so you have to trim it a little to make it snap into the plastic housing. I know it sounds a little confusing, but once you do it yourself, you will know what I am talking about. They were a bit expensive at $2.10 a piece, but in the long run I think I'll be happier with these. On my reciept, it lists them as part number 101065 and the description simply says "Terminal." It is listed in Bin 40E, but that may be specific to the Parts Department here. I hope this helps - Napa may still have the right terminals, but I couldn't wait any longer for them. :) Let me know if you have any questions.
    -Corbin
    P.S. Frank or Earl - do you remember which prongs are high, low, and ground- looking at the back of the headlight with the top terminal up and one the left and right. I would like to have the harnesses all made up before I put them in. See pic below if not sure what I mean... Thanks guys!
    Excuse the drawing - artistically challenged here... :)
  3. 71gold
    :( corbin, sorry to hear about the run around. what we did was put the wires the same as stock. looking at your pic. the red wire is on the top, the green wire is on the right and the black is on the left. we didn't use the black wire. when you pull your stock plug off test it to see if the high is red or green. then mark your relays. if this is not clear let me know and i will try to do better...frank...:bananaman :bananaman
  4. 71gold
    earl, i got the pics. the box looks good.:cool: :cool: ...frank...:bananaman :bananaman
  5. Cleaver
    Cleaver Member
    MD
    Chel
    I was thumbing through a JC Whitney catalog the other day and saw where they have a halogen replacement kit for sealed beam. I think it was like $39.99 for the light housing - then you have to supply your own bulb. Any one have these or similar conversion?
    Cleaver
  6. 71gold
    :rolleyes: corbin, did you get the box and relays in? pics....frank...:bananaman :bananaman
  7. Corbin Johnson
    Hey Frank! Yep I got them in! Finished a few hours ago. I'll post pics tomorrow, when it's light enough to get some good pics. It sure makes a difference - the lights are whiter, brighter, and getting more power - not to mention the difference the new H4 tri-bars I got for Christmas make - they look cool, too. :eek: I'll get some pics tomorrow. The upgrade was easy - the only part that was a pain was getting the bigger wire headlight terminals, but that's not necessary, just something I wanted to do. I did almost fall asleep wrapping the harness with tape, though... :D j/k - took a while, but it turned out good.
  8. Earl Branham
    Lugoff, SC
    Corbin; sorry I didn't respond earlier. My digital camera is a mess, and I did get it to work, just can't figure out how to put the pics up on this board. Glad we were able to help. The light mod is about the best thing we can do for these little cars, for safety. Also, put your fan motor on a relay. It runs the fan better, and no draw on the electrical system. Enough of my chatter! Have a good one!
    Earl
  9. Corbin Johnson
    Hey Earl, I am thinking about doing the fan too. I have the diagram, so when I get some time I may do that too. :D
    -Corbin
  10. Corbin Johnson
    Here's a pic of the relay box - excuse the dirty engine compartment, but it is winter, and it is a daily driver....:rolleyes:
    -Corbin
    All the voltage regulator wiring is bothering me, and I want a single wire alt as I have a feeling this one is going out soon.... Frank, any suggestions as to kind, voltage, etc? :)
  11. Corbin Johnson
    Here's a pic of a headlight. They look pretty cool, IMO. I'll try some day to get a pic of the lights in the light of day.
    -Corbin
  12. 71gold
    :eek: :eek: that's one wicked looking headlight. we need a nite pic. with the ons' on....frank...:bananaman :bananaman
  13. Craig Selvey
    How about a picture of the whole car Corbin??
  14. Corbin Johnson
    Will do Craig, and Frank. Today it's not raining, so I think I'll bring it out and clean it up and post some pics.
    -Corbin
  15. Corbin Johnson
    WOW!! I drove the car for the first time since the light upgrade in complete darkness... It is absolutely amazing the difference. I am not joking, on my car the lights are at least two times as bright. My old high beams were about as bright as my low beams now. It is amazing!:) If anyone is able to do this swap, I HIGHLY recommend it. The combination of Halogen tri-bar headlights (H4) and the wiring upgrade did wonders for my night driving experience. I love being able to see well at night now... :cool:
    -Corbin
