lite relay upgrade done
Discussion in 'Technical' started by 71gold, Dec 15, 2003.
  1. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    A HUGE THANK YOU to Frank and Earl for inspiring me to do this. You guys were correct - this is one of the best upgrades I have ever done to my car. It's a definate nanner job
    :bananaman :bananaman :bananaman
    -Corbin
  2. 74Maverick
    74Maverick Maverick Maniac
    Glassboro, NJ
    1974 Maverick I bought for $500 8 years ago when I was 16. Since then I have invested $30,000 into it.
    Corbin, Love the look of those headlights. I must have missed were you said you got them from. Are they mail order or can you get them from local car dealer? Thanx, Thom
  3. Corbin Johnson
    I got them through a local Mustang supply house, but they are avaliable from Mustangs Plus, and a few other places. They are a bit expensive, but work very well and you only need to replace the bulb when it goes out not the whole assembly. Check out www.mustangsplus.com
    -Corbin
  4. 71gold
    corbin, glad it worked out for you. i know on mine, i get flashed for having my brights on, when they are on low. doesn't piss me off, just makes me glad i did the upgrade. before i didn't get flashed with the brights on...frank...:bananaman :bananaman :bananaman :bananaman
  5. 74Maverick
    Glassboro, NJ
    Thanks Corbin, Im going to attempt this light conversion shortly. I cant wait to be able to see where i am going at night. Thanx again, 74Maverick, Thom:bananaman
  6. MapleMav
    MapleMav Member
    Moose Jaw, SK Canada
    '72 Sprint
    Frank - which area of that Ford Probe did you get that relay box out of (i.e engine compartment/under dash/etc.)? I checked out a Probe last time I was at a wrecking yard and couldn't find the box, so either it was already gone or I wasn't looking in the right place. :slap:
  7. 71gold
    it was on the pass. side under the hood (y) ...frank...
  8. MapleMav
    MapleMav Member
    '72 Sprint
    Thanks Frank! :bananaman :bananaman
  9. 71gold
    ...bringing this back for anyone looking for a cheap light mod...:yup:
    ...:Handshake...
  10. LSU2010
    LSU2010 Brandon B
    Baton Rouge, LA
    '72 mav 2dr, '70 mav 2dr
    read through the post. sounds great.
    Did you use the stock sockets to send the signal to the relays? and, I am still confused, Frank. Did you just replace your stock relays or did you also get a new housing and bulbs, like Corbin?
    The Painless Performance kit used has gone up $50 posted here. Ah, inflation.
    I think these were the Tri-Bars he used. These have a blue tint
    yall used auto zone DF005 relays and a radio shack("got a hobby box from Radio Shack. It is about 6" long, about 4.5" wide, about 2" deep") or ford probe pass fuse box.
    wire and electrical tape for the harnesses. And found wire connectors to fit over the bulb flat pins.
  11. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    OUCH! I got mine from Zoop's for $28.00 each.
    Russ
  12. bomrat
    bomrat Member
    North Little Rock, AR
    74 Comet 4dr 347 4r70w
    i went with a h4 bulb conversion and a hid conversion on top.. works fricken awsome..
  13. darren
    This is on my to do list. Already did a horn relay. Next the headlamps and possibly the blower motor. Trying to replace the high load circuits for piece of mind.
    Cant run HID up here unless its factory. Factory HID has a definite cutt of point for the height of the light beam built into the reflector. Without this those lights blind on coming traffic. Big fine up here.
  14. fastback86
    fastback86 Loose cars and fast women
    FL
    1974 Maverick 351W, 1985 5.0 Mustang coupe, 1996 F150, 2004 Subaru WRX Sti (Don't shoot me, it goes like hell!)
    Those are cool :)
  15. LSU2010
    LSU2010 Brandon B
    Baton Rouge, LA
    JEGS (not zoops but I bought these cuz they be glass not plastic. in case I upgrade to HID :D)
    summit sells the zoops and they say they take H4 and Zoops sales line say they take h2? Russ, any input?
    Sweet. I was thinking light blue HID to match the paint job.
