Little bit of going distances problem
Discussion in 'Technical' started by GenericHbomb, Dec 14, 2007.
  1. 71gold
    chances are...if you had reved the car up a few times it would have sucked the flames down the carb. and went out on its own... with no or little damage.
    ....:yup:...
  2. PaulS
    It shouldn't be able to catch fire with an air cleaner and filter on it. If you are running without a filter then stack fires happen all the time.
    NEVER run an engine without a filter in place - it prevents stack fires.
