Little help needed
Discussion in 'General Maverick/Comet' started by Wizz, Oct 2, 2018.
  1. Wizz
    Wizz Member
    Oakland,ca
    1977 maverick
    So i have a 5.0 in my Mav. Im about to change oil pan gasket. Im going to do a felpro 1 piece. Do i get it for the maverick front sump oil pan or 5.0 rear sump oil pan? Because these are two different part numbers meaning to different parts. They look the same but obviously if they're two different part numbers for different
  2. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    If you have the front sump pan, get the front sump gasket.
  3. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    When in doubt I purchase both and return the one I don’t use.
  4. yellow75
    Tillamook Oregon
    Unless your shock towers have been removed and suspension changed you have a front sump, easy enough to figure out by just looking at your pan you have on it, if its deep in the front then it is a front sump
  5. Wizz
    Wizz Member
    Oakland,ca
    1977 maverick
    Yea i have a front sump. But do i get a 5.0 gasket or early 302 gasket
  6. yellow75
    Tillamook Oregon
  7. Hotrock
    Munroe Falls, Ohio
  8. yellow75
    Tillamook Oregon
    Hotrock did you use an original 302 pan or an after market pan ?
  9. Hotrock
    Munroe Falls, Ohio
    I used a heavy after market cast aluminum pan.
  10. Mavman72
    If your oil dipstick is in the side of the block...Get the 5.0 gasket. If its in the front cover...get the old school gasket. Either way get the one piece gasket.
  11. groberts101
    groberts101 Member
    Minneapolis, MN
    AFAIK.. the blocks pan rails are the same for all 302's which is what matters. Pick a brand, Ford, felpro, mr gasket, etc, of 1 piece design with steel cored crush limiters and go with it.
    Hotrock and Krazy Comet like this.
  12. Krazy Comet
    Yep, only pan differs.
  13. Wizz
    Wizz Member
    Oakland,ca
    1977 maverick
    Thanks fellas. I got the one for the Maverick front sump pan by Fel-Pro one piece
