Lock Right / Powertrax
Discussion in 'Technical' started by 19MAVERICK72, Aug 18, 2006.
  1. RegL404
    RegL404 Member
    The 8 and 9" uses threaded adjusters to set the backlash and bearing preload, not spacers/shims like a dana. Once you take the carrier out it takes some setting it back up. You have to tighten/loosen side to side until you get the backlash and bearing preload back as close to original as possible. No way to just pop it back in like on a dana.
