Long-awaited (small)upgrade on a stock Maverick?!
Discussion in 'General Maverick/Comet' started by Jony, Oct 19, 2019.
  1. Jony
    Jony Member
    1972 Ford Maverick Grabber 5.0L 302 v8 NA
    I'VE MADE A SURVEY (QUESTIONNAIRE) TO HELP GET MORE OF A CONCRETE DECISION! PLEASE CLICK THE LINK TO HELP, I'D REALLY APPRECIATE IT!!!
    https://www.surveymonkey.com/r/2DM65GQ
    LET ME KNOW IF THERE IS OTHER INFO. NEEDED!!
    I WILL BE MAKING THE DECISION FINAL SOON, NO LATER THAN A FEW DAYS! ONCE IT IS DECIDED ORDERS WILL BE PLACED!!
    Two sets of NEW wheels:
    - FRONT: (x2)Pro Comp Xtreme Alloy Series 7069
    - 15" Dia. x 8" W
    - 5 x 4.5" Bolt pattern
    - 3.75" Backspacing
    - -19mm offset
    - P205/75/15 Tires
    BACK: (x2)Pro Comp Xtreme Alloy Series 7069
    - 15" Dia. x 10" W
    - 3.635" Backspacing
    - -46mm offset
    - P255/60/15 Tires
    Compared to the current wheels:
    - FRONT: (x2)Pacer
    - 15" Dia. x 7" W
    - Backspacing (UNKNOWN)
    - -offset (UNKNOWN)
    - P245/60/15 Tires
    BACK: (x2)Pacer
    - 15" Dia. x 8" W
    - -offset (UNKNOWN)
    - P245/60/15 Tires
    SHOULD I COMMIT TO THE UPGRADE?
    I've received many suggestions from repairing the valve stems and new valve stems to new tires and maybe new wheels. I don't know what to go with anymore because they all sound great.
  2. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Replace the valves with NEW .. Why would you want an ' used ' stem in your NEW WHEELS ??
    jasonwthompson likes this.
  3. Jony
    Jony Member
    My bad, I didn’t leave much explained but it’s basically another forum based on the previous one I posted right before this one! I just had a problem with the valve stems on my current set of wheels and asked a question about if I should stick with the old and get it replaced both stem and tires or go new with an entire new set.
    Sorry about that!!
  4. 71gold
    the 255/60/15s on 10" rims are going to buldge the sidewall...:yup:
    I ran 275/60/15s on 8" rims with no rubbing.
  5. Lee Richart
    Lee Richart Member
    Redford, MI
    1973 Maverick LDO 421W
    I agree with Frank on the rear wheel width. Also 8" is too wide for the fronts. For the 75 series 6" would be adequate and 7" would be max. I run 215/60x15s in the front and 255/60x15s in the rear all on 15x7 wheels and they work great.
    Lee "THE MAV" Richart
    ike72com likes this.
  6. ike72com
    ike72com Member
    Charleston SC
    Hello, please update. What did you decide? Tires and wheels
    If installed yet would love to see pic.
    Thank you
