Look ma, no bumper bolts
Discussion in 'General Maverick/Comet' started by Mavaholic, Dec 1, 2004.
  1. PART-TIME
    PART-TIME Member
    Ocoee, Fl.
    Grabber Clone
    Looks great Dennis. Original idea? Man you've gotta slow down. It's hard work trying to keep up with the Jones.
  2. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Dennis definitely has too much time on his hands.
    I think he should get married again.
    What do you guys say we sign him up on the
    E-Harmony website.
    j/k
    Seth
  3. rayzorsharp
    Dennis, I love the bumper effect. I can suggest the next time you weld up the holes to try tig welding instead of mig. It's a little tougher and slower but the metal melts in better and you can get rid of the air pockets or pin holes. It might be worth paying someone to tig-weld the holes next time if you can't do it yourself. I would have thought the bumper people could have taken care of the problem though before they plated it. I just recently had $5000 worth of parts chromed at a replater for a 61 Cadillac I restored for someone. Some of it came back with pits in it. For 5 grand it was unacceptable. The second time it came back pretty much perfect. Just proves they can do it when they want to.
    Anyway, your car looks great but of course you already know that. I hope to see it in person soon. (y)
  4. GrabberJoe
    GrabberJoe Member
    Brooklyn, Michigan
    1974 Maverick Grabber
    Dennis, That looks excellent! Nice work!
  5. lilgreenmav
    lilgreenmav Lilgreenmav
    Columbus Ga.
    Sweeeeeeeett!!!
  6. Mavaholic
    Thats a good idea. My company has a small Tig that I use for work so I can get it almost anytime I want to.
    I thought they would have at least called me up and given me the option to pay them to fix it. I dont blame them for the problem, but with the restoration work I've seen from them, I know they could have done it. Right now I cant afford to get snooty with them because they forgot to send my valance panel back. As soon as I get that, I will register the complaint. Needless to say, I wont be using them again.
  7. Shorty
    Shorty Member
    Lafayette, In
    Are those Mercury Bobcat or Brazillian Maverick taillights?
  8. Mavaholic
    Neither, the answer lies above.
  9. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Dennis, from down here in Bama, sure looks good to me. Love the GM tail lights,look like they were made for the car! Now, any time you want to fix mine up for me, I'll let you practice on it anytime! Hope mine turns out half that good!(y) (y) (y) (y) (y)
  10. riporter
    riporter Member
    Charleston S.C.
    I think it looks really sharp...but it always has. I would use a minimum 15% silver content brazing rod with flux with an oxy/acet setup at the right temp...good flow properties and no porosity, a 50% rod would be better, flow is even better. I don't have much experience in tig so brazing would be my choice.
  11. Mavaholic
    The way I did it was to weld up the holes in the mounts and smooth them out first. Then attach the mounts to the car, hold the bumper in place, and tack the bumper to the mounts with the mig. Once tacked good, remove the bumper and mounts and weld the mounts to the bumper on the back side with the mig. On the next one I will probably just use the tig to tack the bumper to the mounts. I will still mig the back side. Then I will tig the bumper to the mounts through the bumper bolt holes on the front side until I have a good bead all around the perimeter of the hole. From there I will braze up the rest of the hole. The brass will be much easier to sand and will result in much less or even no depression in the surrounding metal.
  12. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    you should be able to braze the hole up completely with a brass rod, just back it with a penny, that's what my stepfather does, I think, then you can sand the braze down with paper I would immagine, harder than lead, softer than steel
  13. DaMadman
    Southern MD
    Maverick 1972,1970,1973
    Better make sure it is an older penny. Sometime in the early to mid 1980's the gov't quite making pennies out of solid copper and started using zinc with a copper plating over the zinc and let em tell you, zinc melts away very quickly and at a lot lower temp than copper.
  14. rayzorsharp
    I'm bettin he figured that out about 3 years ago... :rolleyes:
