Looking at replacing to a 9" rear
Discussion in 'Drag Racing' started by pil1sbury, Feb 16, 2016.
  1. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    If you ever get to see the Classic Gear Jammers race,tell me how many 8.8s you see,same with Pro Stick.
  2. 351Blueblood
    351Blueblood Member
    How about you go to any drag strip and tell me how many 8.8 's you see?
  3. groberts101
    groberts101 Member
    Minneapolis, MN
    All the very serious cars that came equipped with them will swap away from the 8.8's to the 9". And all the serious cars that didn't come with them in the first place will rarely build an 8.8" over a 9". Not just about the power levels either.. lots of 1,000+ horse boosted cars out there using premium OEM parts.. but moreso depends on how hard the car leaves and hits the rear gears/axles(sudden high rpm shock hurts parts much easier than progressively loading them at even higher power levels).. and also how much budget is available.
    Can you put serious power down and make an 8.8" work for years?.. yep. Lots of very fast cars out there using them. Then again.. lots of very fast cars out there running stock transmissions(T5's and T56's) that are rated for FAR less power than they are being subjected to as well. Do those cars side step their clutches at 6,000 rpm on slicks to run those ET's?.. no way.
    Despite that, all the guys I've talked to that race them harder say that it doesn't make much sense to build and toss all new parts/modify an 8.8" setup to work in place of the 9". And.. to just say no to c-clips.
    Right or wrong.. sometimes monkey's just keep doing what they see all the other monkey's doing. Yet 9" conversions are still popular for a reason.
    But.. who really cares about all that when the OP isn't going to notice one way or the other at a more reasonable power level typically seen on a street/strip car. If 8.8"?.. still wise to use c-clip eliminators though because it's no damned fun at all when they break.
  4. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Yup:yup:
  5. 351Blueblood
    351Blueblood Member
    Why the Ford 8.8?
    There are many reasons to use a Ford Explorer 8.8 from the 1995-2004 Ford Explorer. Here are a few key “pluses”
    • Easily found at almost any junk yard
    • Variety of gear ratios and options (LSD, open diff, etc.) available
    • Easy to fit into most RWD vehicles
    • Rear disc brakes (typically an upgrade)
    • Common 5 x 114.3 0R 5 on 4 ½ lug pattern
    • Plenty of Aftermarket support for future upgrades
    • Very strong. Handles abuse from track racing to offroad and everything in between
    • 31 Spline axles.
  6. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    I am not here to put down anyone,only to try to help & I do not know everything.It`s your money,however,no 8.8 is ever going to hold up like a 9,especially when you start talking spools,35 & 40 spline axles,Mark Williams,Moser & Strange housings,there is no comparison.Plus,if you have 2 hogsheads it is fairly easy to have 2 gear set ups for diff. tracks & swapping them out is not to difficult,a lot harder w/ an 8.8.
  7. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    I think there is room for both under our Fords. Depends if you are building a dedicated race car or one for dual use. Most racers would build a 9" for a race car for the reasons stated in multiple posts on this thread, including me. It is a flat out stronger and more versatile rear end than an 8.8'. Having said that, I would have to be making sick HP to motivate me to swap out an 8.8 for a 9" on a dual use car and as groberts pointed out, the clips would have to go in favor of bolted axle flanges.
    bossmav likes this.
  8. 351Blueblood
    351Blueblood Member
    Sure everyone knows 9 inch is stronger then 8.8. But for the OP's use the 8.8 is great alternative. It's super cost effective that's for sure. And also I have a 9 inch in my drag car. Not here to step on toes just show other options.
  9. bossmav
    bossmav Drag racing nut
    Harrisonburg, Va
    74 Grabber now Pearl white
    rotorr22, you nail it!
  10. maverick306
    maverick306 Member
    Kinston NC 28501
    1974 ford maverick
    I got my housing and hog head with 3.89 gear in 1999 have no problems with it I am running 28 splice axles. Western Drivetrain, Inc 303-364-8098 Bill Abel
  11. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    $159.00 eliminates the c-clip. I have a 9" in my car but I may some day swap it for an 8.8. Absolutely everything about it is cheaper but with that said iv never broken anything on my 9" and iv probably made more passes and street miles than 90% of these guys.
  12. mav man
    mav man Member
    wi
    70mav
    I went with a 59 Ford 9" 50$ at junkyard rebuilt possi with 3:50 gears. Axles are weak ,I run them on road and got a set of good axle and spool for track. Everything bolts right in and for around 400$ I've got a 9" track lock possi and another set of good axles and spool for track.
  13. murphy88
    murphy88 Member
    waterloo on
    73 maverick 76comet
    I built a 9 inch housing for my maverick...I have the 28 spline maverick axels in it now..I have some 389 gears on a spool...a mustang aluminum driveshaft..car goes 11.95 with some old drag ta drag radials ...has any one used a 28 spline mini spool at drag track ??are the strong. ...??my brother has some 430 on a mini spool chunk..we ran them in a oval track car a few years sgo
  14. 351Blueblood
    351Blueblood Member
    I have a 8.8 28 spline mini spool in my 1993 Lincoln Mk8 with IRS with CV shafts running 11.3's at 3700 lbs. The mini spool is getting beat up that's for sure. You can buy 28 spline full spools for cheap too.
  15. Mavric65
    Mavric65 Member
    Sacramento California
    1973 Maverick
    I ran a mini spool for years and never had a problem I broke 2 axels at different times with it the mini spool needs the hardened pin then all you have to worry about is the carrier but I personally never had a problem and I was running 12.0s at 115 through the mufflers back in the day
