looking into efi and a t-5????
Discussion in 'Technical' started by sam03rc, Jan 1, 2011.
  1. Dave B
    Especially, if you don't have everything, or a lot of experience.
  2. sam03rc
    sam03rc Member
    gates county, nc
    1972 maverick 302 C4
    im looking in to this system for efi now
    Powerjection III returnless system
    its under 2k and requires no tuning or mods just drop and go it looks like all the write ups i found the people did it in under a couple hours and drove it that after noon and cons thou???
  3. Bryant
    the ez efi was really easy. the fuel system is the hardest part and that is what you will have to deal with on any fuel injection anyways. i got the kit that didnt include the fuel pump and all its stuff. next time i do it i will get that kit. i had to get a fuel pressure regulator, pump, prefilter and filter. also had to run a return line in the car. the throttle body just bolts on like a carb. the wireing only needs to have a power and ground wire ran to the battery, a wire to the ignition wire, a tach signla wire then its ready to be started. it also has an eletric fan controle wire and an a/c wire to detect when your a/c is on to increase the idle speed and turn on the eletric fan.
