lowered mav/comet
Discussion in 'Technical' started by slick, Dec 1, 2011.
  1. igoback70
    igoback70 Member
    IN
    70 Maverick
  2. igoback70
    igoback70 Member
    IN
    70 Maverick
    Scratch that--- lol the last pic is with air-shocks installed and bumped up.
  3. slick
    slick Member
    somerset, ky
    73 comet, 72 maverick
    thanks for the pics man..is the car finished yet?
  4. igoback70
    igoback70 Member
    IN
    70 Maverick
    Nope, runs and drives ---- needs more sanding and paint put on it. It's 10 miles from my house to it, so i usually only work on it 1 or 2 days a week, and there have been times when i havent touched it for months.
  5. Dave B
    I have no idea, I've never measured it. I just set it up to look the way I wanted it to.
  6. Streamliner
    Streamliner Member
    Anything more than a 2" block in the rear and you have to be concerned with driveshaft to floor contact towards the rear
  7. slick
    slick Member
    somerset, ky
    just picked up some universal 1" lowering blocks this evening, hope to get them put on asap. on a side note DDB you have an awesome little car, i love the stance
  8. Dave B
    Are the lowering blocks you have solid? Don't use them if they are those cheap cast aluminum ones.
    Thanks, wait till you see my next one :D
  9. igoback70
    igoback70 Member
    IN
    70 Maverick
    Heres few pics of my Mav's stance slick, i think you should take the advice of eveyone who has said to cut a half coil at a time on the front. I cut half a coil off mine, went to install and thought the spring was still way to tight in the compressor, so i cut another half off ---- i wish now that i would have stop at the half mark, but what's done is done. I'll just have to wait and see what it sits like after alignment and rims and tires installed. :banghead:
  10. slick
    slick Member
    somerset, ky
    too bad you cant add back on to the spring if you cut too much:huh:..i think 1/2 a coil is the general concensus, thats where im gonna start. im also running a set staggered wheels so the front will come down a little anyways
  11. igoback70
    igoback70 Member
    IN
    70 Maverick
    Yep, but i figure what the heck, worst case scenario i will have to spend another $100 to change it back. Right now it's a wait and see game, drives nice and soft though.
  12. slick
    slick Member
    somerset, ky
    thats why i didnt want to heat my springs, i know the ride quality would go away if i went that route. the car rides pretty nice now so i dont want to mess that up
  13. igoback70
    igoback70 Member
    IN
    70 Maverick
    :thumbs2: Never a good idea to use heat on em. The springs that are in it came out of a 76 i found in a JY, big bumpers --- AC, when i installed them it looked like the car could hold a big block with no problems.
  14. blugene
    Man that's low.. Almost slammed lol.
    I have seen guys heat the springs and it be different from left to right cause they react and fall different to each other. I also seen one guy tweek a ride height on a truck by heating one side. Brought it down to match the lower side. He seemed to know just how much heat to add. I still think it was a gamble..
  15. slick
    slick Member
    somerset, ky
    i just realized today when i got under the car that i have air shocks in the back, i ended up raising the back about an inch so id have a little bit of rake. the car is still gonna come down an inch all the way around cause its just to high. one thing i also found was the car is about 5/8 to 3/4 of an inch lower on the drivers side rear..anyone know why?how to fix it?
