Lt1 In A Maverick?
Discussion in 'Parts Interchange' started by ssakayeda, Apr 9, 2004.
  1. rcomet75
    rcomet75 Member
  2. Grabber-1
    Grabber-1 Member
    long island ny
    71 maverick
  3. stmanser
    Davenport, Iowa
    lets get back to the point
    MAVERICKS are worth doing anything to. they are light and FAST!
    if you dont like maverick, get OUT!
  4. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    Quite talking and start "doin" :yup: :bowdown: :bouncy: :D
  5. johnson
    johnson Member
    fargo, ok
    69.5 maverick
    all i can say is accept the criticism. i wanted to put a roof scoop on mine and whew did i get smacked up side the head by just about everyone that responded
  6. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    isnt there another thread kind of along the same topic as this. i love all cars but would never mix motors,just my 2 cents. good luck
  7. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    If you really want that Mav to be fast, use an LS1 variant... (LS1,LS2,LS6)
    The small block Chevy has been done to death. I have seen pics of them in the Maverick, some with the shock towers still in place (but shaved).
    It should be 'relatively' easy with an M2 suspension.
    Then you would just need to fab headers and engine mounts for the most part. A tranny crossmember with a small GM tranny, then put a hybrid driveshaft together to mate it all up. You never know, a T350 might not even need the shaft length altered. If that was the case, you could just use a swap u-joint up front and be done with the driveline.
    Good luck
    Take pics
    Dave
    Btw: Personally I do not agree with the swap idea, but it is NOT MY CAR!
  8. jim_barbier
    jim_barbier Member
    atlanta ga
    if you wanna drop a chevy motor in a ford go with the older trucks they fit well and motor mounts are easy to make work but a maverick if u wanna make it fast with the difficulty u are talking about put a 351 in it it would be cheaper and easyer put the lt1 in an old nova or ventura same thing diff. grill and tail lights little heavyer but suff. for a good motor played with them in my earlyer years and oh yea dont forget the omega better looking than the ventura front end and tail lights good luck dude
  9. dchoux
    dchoux Member
    Madisonville, Louisiana
    1975 2dr Maverick 302 4 spd
    Yes, it will work....
    Ok, forget the Mustang II suspension. It seems nobody has an open mind here. Let's all take a look under the hood and under the front end, of a 65-67 Chevy II / Nova. It has the same basic design as the Mavericks do. I helped a friend out years ago with a small block Chevy sway into a '67 Mustang. You go get the iol pan, oil pump and oil pump pick up tube the the old Chevy II. Then, you may have to fabricate or buy the engine swap mounts. We made solid mounts on the Mustang conversion. The trans mount situation was simple enough too. It was a matter of getting the right mount for the GM trans and it bolted right on the Maverick V-8 trans. bracket. Exhaust may be a little tricky, but, still manageable. You may get lucky with a set for the Chevy II or you may have to run stock manifolds. But, you may have to look find ones that have different outlet positions. All in all, it is possible to do. Hope this helps. (y)
  10. Mavaholic
    Thats pretty good. Now tell me how to put a 351W in a 64 corvette. Then tell me all about narrowed minded people. :D
  11. CometGT1974
    CometGT1974 Gearhead
    Western NC
    74 Comet GT
    Now Dennis, you'd have to be crazy to put a good motor like a 351W down in a piece of crap vette!!:D
  12. stmanser
    Davenport, Iowa
    nice video comet gt.....i liked it alot.....what length tracks were in there.....looked like 1/8th and 1/4?
    whats the best time and mph yuo have?
  13. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    :mad: I aint narrow minded, just a skinny thinker.:bananaman
    mad73mav likes this.
  14. dchoux
    dchoux Member
    Narrow minded??
    Well, the term 'Narrow Minded' was not used. I said 'open minded'. I am NOT a GM fan by no means. I've never owned a GM product. I have had 4 Mavericks and 2 Ford trucks and a '72 Cougar at one poing in time. I was just trying to help exlpain how to go about the process of doing the nasty.....installing a GM motor in a Ford.....Maverick at that. Now, Let's see....a 351w in a '64 vette.......How about start looking at an oil pan from an early Enonoline....LOL....:hmmm:
  15. Dan Starnes
    West Central IL
    This thread keeps re-appearing. I have always wondered if the LT1 was ever installed?
    Dan
