lug nuts
Discussion in 'Technical' started by garry kilgore, Dec 10, 2015.
  1. garry kilgore
    garry kilgore maverick 2
    ga.
    1972 maverick
    what style lug nuts do you use on 1973 ford maverick with factory aluminum wheels
  2. Craig Selvey
    From the factory it took a long chrome lugnut. About 3" long.
  3. garry kilgore
    ga.
    1972 maverick
    will acorn style lug nuts fit or magnum 500
  4. Craig Selvey
    The acorn style fit, but they are a little short in my opinion.
  5. Paul Masson
    1971 Grabber
    I used a set of McGard nuts I picked up at Canadian Tire. They are short, but I inadvertently ended up buying the 1/2"-20 that uses a 19mm socket instead of the 21mm socket like the originals would have. This smaller hex allows for a smaller socket which keeps the outer diameter of the socket away from the wheel when removing/installing the nuts. A longer nut wouldn't require this, as the socket would be engaging the lug nut before the holes in the wheel. Personally, I like short lug nuts and short valve stems on a wheel... and all my tires clocked the same way wrt each wheel... i can check the McGard numbers on the nuts when I get home if you want.
    Here are some pictures of the wheels from different angles.
  6. garry kilgore
    ga.
    1972 maverick
    yes check lug nut numbers let me know
  7. groberts101
    groberts101 Member
    Minneapolis, MN
    IIRC, most all old Ford wheels(and Magnums too) use a ball seat style lugnut. Just be sure they are not tapered style seat as those will chew into the wheels and eat up the lugnuts after a few R&R's.
  8. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    I use Gorilla brand lug nuts that have the smallest OD of any I have found. They even provide you with a special wrench when you buy a set of 20. I have AR "Maverick" rims where the lug nuts go into a deep counter bore. Not much room for a regular socket.
