lug stud knurl size?
Discussion in 'Technical' started by Joe Dirt, Jul 17, 2009.
  1. Joe Dirt
    my knurl is .545 also were did you get your studs
    i drilled my rotors out and used fox body mustang 3" moroso studs in the front
  2. yellow75
    Tillamook Oregon
    Picked mine up at CarQuest, Napa should have them also. But they are stock length.
    Thanks for the tip on front, how hard was it to drill the rotors?
  3. Joe Dirt
    edit,needing a 3" stud on mine
    the rotors arent that bad to drill the out the material for the larger knurl studs.I just didnt want to drill my axles out as there not as easy to replace as the rotor:rofl2:
  4. 71gold
    the size of the knurl doesn't matter as long as it is bigger than the orginal hole...the trick is to get the correct size drill bit and then don't let it oversize the hole. do it in a drill press if possible...:thumbs2:
