M/C failure?
Discussion in 'Technical' started by NWMO_Maverick, Dec 3, 2019.
  1. NWMO_Maverick
    NWMO_Maverick Member
    Northwest MO
    Hey all,
    The brakes on the 76’ (power) Maverick are laying down. It’s losing fluid between the M/C and booster. Even when you pump the brakes, it loads up briefly and then goes away. I assume a new M/C is the answer, the lines look good.
    Chris & Gabe
  2. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Yep, fluid coming out the back is a bad cylinder.
  3. lastchance
    lastchance Member
    Hingham , Massachusetts
    Probably should change the booster also. Brake fluid usually ruins them.
