Mabe pushrods....
Discussion in 'Technical' started by justin has a 74, Sep 2, 2010.
  1. justin has a 74
    kentucky
    Were you not paying attenetion in the other threads or are you still pissy over the whole " i passed a funeral going 5 mph in the opposite lane to prevent an accident" Stop acting like your in elementary school and grow up. I grinded down the pedestols on the other heads since the valve train wasn't right. THe pedestol i grinded down wasn't flat at the bottom, 500 lift cam broke the bolt and the intake side didnt know what the hell to do with the exhaust rocker arm getting in the way:16suspect
  2. Bryant
    ok this is new info. please elabirate. post pics if you can. grinding the pedestols is not a good idea. you should get shorter push rods.
  3. justin has a 74
    kentucky
    On the old heads, not the new heads. The new heads are completely stock or i would have mentioned it (not trying to agrivate you bryant:Handshake)
  4. baddad457
    Stock E7 heads = bolt the rockers down and torque to 20 ft/lbs. :tiphat:
  5. PaulS
    My 73 302 is a positive stop rocker assembly - torque to specs and thats it.
    My Muskrat I have to maually adjust becaust I installed screw-in studs and roller rockers.
