Major set back AGAIN!!
Discussion in 'Other Automotive Tech & Talk' started by blugene, Aug 24, 2014.
  1. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Gene, what's the verdict - original or not ? ? ?
  2. blugene
    blugene Senior member
    Really hard to say. I could swear that there are bolts that have not been touched. I took a rod cap off and it's .025.. BUT, that don't mean they didn't just slap some over sized bearing onto my crank that had 250k on it. I just don't know.. It does look like it spun a bearing though.
    I :smash: on it for little more than 8 hours today and it don't show. Most of the day was spent on my back.
    Took a short video of the broken crank..
  3. 71gold
    I've never heard of a .025 bearing...:huh:
  4. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Actually, I was referring to whether you'd had time to check your block's serial number against the VIN tag on the dash...
  5. blugene
    I was told that was not possible.. I do have the block # here in front of me and my title in the safe.. Do you know if I can and how?
  6. blugene
    One other note. The new block I just bought has a tag on it's side right where the casting #s are on my broken one. What I am to understand is that my busted one SHOULD have had one. But again, not sure if that is correct information.
  7. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Numbers should be hard-stamped into the pad on the block. For instance, the last 6 numbers on my ('98 Dakota) VIN are 671803. I'm thinking those numbers should match the numbers on the block. But then, I'm prolly just reverting to my GM roots and ASSuming this is the same across all makes...
  8. blugene
    I'll look anyway when I get a chance today.
    Edit: Just looked. Nothing even close..
