Manifold removal
Discussion in 'Technical' started by Bob Wiken, Jan 20, 2008.
  1. 71gold
    nothing to be...sorry...about.
    when i start hauling mine on a trailer i will get me an extra set...
    along with...plugs...plug wires...oil...oil filter...water...fuel...fuel filter...air filter...dist. cap...dist...coil...etc...etc...
    ...:huh:...
  2. scooper77515
    As I stated earlier in the thread, they come in a 12-pak. For 6 cyl cars. In order to get 16 (for 8 cylinders, just in case you aren't keeping up here...;)) I had to buy 2 sets. So at this point I have 8 spares...
    Then I bought another set of longer ones to use on the spacer side of the P heads, so that leaves me with quite a few spares...
    So even after I ship a bunch off to Bob, I will still have a bunch of spares.
  3. maverick1970
    maverick1970 MCG State Rep
    Missouri
    The true reason they come in packs of 12 is because the Small Block Chevy only uses 6 per side. Sad but true.
  4. scooper77515
    What is the bolt pattern for the SBC that makes it use 6...is it because the middle two tubes are almost together?
